What is this Electrical "thing?"
PostPost by: Cinbearcat83 » Mon Jul 29, 2024 4:29 pm
My brother and I are starting to tackle the wiring on the +2. The alternator is a Lucas 17ACR. The previous owner made some "workaround" wiring changes that we are trying to diagnose. I have attached two photos with questions:
1. Two wires off the alternator are (reddish/orange) are spliced together at the yellow connector. The wiring diagram shows separate circuits: one wire goes to the tach/coil, the other wire splices and runs to a brown/white that goes to four different circuits. How do we distinguish which wire from the alternator goes to which circuit?
2. The combined reddish/orange wire runs to an electrical "thing." What is this? See the second photo. Is this a regulator?
Thanks for your help,
Kevin
IMG_8251_reduced.JPG and
Alternator Wiring
IMG_8250_reduced.jpg and
Electrical "Thing"
Kevin
1972 Elan +2 S130
Cinbearcat83
First Gear
First Gear
PostPost by: shynsy » Mon Jul 29, 2024 5:56 pm
Looks like a noise suppressor. Stops electronic noise making your radio buzz and crackle.
Current Cars: '72 Elan +2S130/5, '72 Triumph Stag 3.9L, '72 Spitifire Mk IV. Past Cars: '72 Triumph TR6 (supercharged), '70 MG Midget (K-Series + Type 9), '76 Triumph 2500TC, '72 Lotus Elan +2S130/4, '76 Triumph Spitfire 1500.
shynsy
PostPost by: ncm » Mon Jul 29, 2024 8:16 pm
Hi Kevin,
If you remove the plug from the rear of the alternator you should find that the two "reddish/orange" wires are connected to the large spade terminals ( which are connected internally). These are the wires that connect to the brown/white that you have identified on the wiring diagram. The third wire from the smaller terminal ( looks to be a blue wire) should connect to a brown/yellow that runs to the ignition warning light.
Brian.
PostPost by: Cinbearcat83 » Tue Jul 30, 2024 2:03 am
shynsy wrote:Looks like a noise suppressor. Stops electronic noise making your radio buzz and crackle.
Thank you - I would have never guessed that! - Kevin
Kevin
1972 Elan +2 S130
Cinbearcat83
First Gear
First Gear
PostPost by: Cinbearcat83 » Tue Jul 30, 2024 2:05 am
ncm wrote:Hi Kevin,
Brian.
Thank you. This is helpful - Kevin
Kevin
1972 Elan +2 S130
Cinbearcat83
First Gear
First Gear
PostPost by: Andy8421 » Tue Jul 30, 2024 4:47 am
Kevin,
At the risk of telling you something you already know, that wiring looks terrible. Many an Elan is now in the parking lot in the sky because of fires caused by wiring issues.
Depending on your plans, I would either start from scratch and replace the loom entirely, or if not, go through all the wiring cutting out all previous owner's bodges and replace to a good standard. Its often under the dash that the real horrors are lurking.
Regarding the 'thing' it looks to be an in-line suppressor to stop the annoying alternator whine that cheapo radios can pick up. Typically it would need to be earthed to work (hence the tag with a bolt hole). Throw it in the nearest bin, along with all the attached wiring. Although wimpy by modern standards, with a flat battery, headlights, heater and wiper on, a 17ACR will output 36 amps and the wiring attached to it needs to be able to carry at least that.
There are threads on here about replacing a dynamo with an alternator which may help.
Good luck.
32 Standard 12
Various modern stuff
PostPost by: Elanman99 » Tue Jul 30, 2024 7:36 am
I totally agree with what Kevin has said.
From what we can see in the picture the wiring is in a very poor state and if its not something that you are able to do then I would recommend getting professional help, preferably from someone with Lotus experience.
The workshop manual is a 'must-have' .
Ian
Elanman99
PostPost by: Cinbearcat83 » Tue Jul 30, 2024 3:21 pm
Andy8421 wrote:Kevin,
Good luck.
Good feedback - thanks. Yes, the wiring at the alternator is a mess. We are attempting to figure out what the previous owner was trying to do. - Kevin
Kevin
1972 Elan +2 S130
Cinbearcat83
First Gear
First Gear
PostPost by: Cinbearcat83 » Tue Jul 30, 2024 3:23 pm
Elanman99 wrote:I totally agree with what Kevin has said.
Ian
I agree it's in a very poor state. We do have a workshop manual. I am thankful to have my brother to assist me. He is a Master Automotive Technician and is a big help. - thanks for your comments. - Kevin
Kevin
1972 Elan +2 S130
Cinbearcat83
First Gear
First Gear
