Wiring Loom Plus 2
After hours of fiddling, biting the bullet and taking it for professional help, the diagnosis is that it would be best to fit a completely new wiring loom and start from scratch.
So, the embarrassing thing is, I don't really know what version of car it is, so can't order the loom!!
It is 1968, RHD, it has 2 fuses and an alternator, I believe it has a voltage stabilizer? (black box bolted to bulkhead - Pic 3), so its not a US model.
Can anyone advise on version, and sourcing wiring loom (Klevedon Lotus?)
Many thanks
Many thanks
- Marcus+2
Autosparks made the original wiring harnesses.
It's where I bought mine from and no issues whatsoever.
https://www.autosparks.co.uk/
Lotus fan - Second Gear
No direct experience with the Autosparks looms, but have read a lot of threads referencing them. I actually was too daunted by your exact concern when I was new to the car and wanted to install all new wiring as mine appeared to be pretty bodged over the years. I went with a Spyder supplied loom instead, which ended up working out OK but needed a lot of modifications. Just offered as background, not a recommendation.
My understanding is the same variety of Autosparks Plus 2 looms are sold in North America by British Wiring. Their website below might help you in determining the best three looms to order as in some respects the descriptions seem a bit better. The Kelventon descriptions also help, and I assume they are also Autosparks, so thinking it is an order wherever you prefer type deal.
http://www.britishwiring.com/Lotus-s/11.htm
If I understand your question, sounds like an exact description of a few key details for your car would help a bunch. I am expecting whatever loom variants you select some modification may be required. I don’t think this will be that big a deal because all the descriptions describe them as wrapped with hopefully non-adhesive loom tape. This allows generally quite easy modification of the loom as required.
Can you describe your car in broad details a bit? Obviously some of these you already provided
The biggest remaining difference between the looms seems to be the generator or alternator arrangements. Perhaps take a few additional pictures of the Regulator Box and the actual alternator with its wiring and someone way more knowledgeable than me can help you out.
Most more modern alternator conversions use a lightweight and compact NipponDenso based alternator kit that has the regulator inside the case. This makes the wiring way simpler. I think your setup is different, and may be either requiring the external regulator you have identified on the firewall, or the guts of the regulator have been modified. If you are comfortable and and able, a few pictures of what is presently connected to this regulator and a picture with the cover removed will assist in identifying what you have. That said, you can simply “upgrade” to the NipponDenso style arrangement in conjunction with your rewire.
As usual, sorry for the length, but without a few more details it is probably kind of hard for the Autosparks cognoscenti on here to provide a helpful answer beyond that they all generally describe the Autosparks looms as good quality but hard to identify.
As I say, I had exactly the same concerns when new to my car. When I actually gained a better understanding of a few Plus 2 wiring quirks (from excellent answers here on the forum) and had the original looms totally out of the car I found out that my original wiring (eliminating all the previous owners modifications and bodges) actually followed the Lotus WSM Federal Plus 2 exactly. Still glad I upgraded things, but I probably could have started with the correctly selected Autosparks looms if I could better answer a few identifying features. At any rate, I am sure the forum can easily help you out enough to knowledgeably discuss your specific requirements with the various suppliers.
Once you get your selected loom suite, you can pretty easily make note of what you might want to add or modify in conjunction with your rewire. Some common adders and changes include the following, and all have lots of separate threads with details. The main point is to decide on your final scope before putting your new looms into the car and installing the dash. Not a general recommendation of changes, just a shot at a list to consider or dismiss…
HTH
- RHD
- 1968 Assuming this is based on registration date rather than build date? Can make a difference.
- Only a single fuse box with two glass fuses? You may want to change this or not.
- Full VIN (50/####) Your car can be compared to the published Robinshaw & Ross listing of rough introduction dates and serial numbers to describe the model and the key needed features.
- Four minor gauges or six? This is probably the biggest difference maker in the dash loom selections.
- Ammeter or “Battery Condition Meter” (voltmeter)? Two part question; what do you have now and what would you like to install? Lotus advised in the WSM to charge to a voltmeter if an alternator is installed retroactively.
- Emergency flashers present?
- A picture showing the light switch arrangements for the sidelights and the headlights, and perhaps a picture of the microswitches that are probably at the front of the bonnet closure (sort of like the door switches).
- Rat tail toggle style or flat rocker switches? This is probably the second biggest detail in the dash loom portion.
- Front fog/driving lights installed?
- Presence or absence of the later additional auxiliary lighting (under the bonnet, boot, doors, glove box). Think this is all absent on your car by the age?
- Presence or absence of an actual element for rear screen defrost heat and presence or absence of a dedicated dash switch. e.g. My Federal car didn’t have the element or wiring, but the switch was there.
- A few general layout pictures of the dash to determine the various warning lights, switches, etc.
- Wiring for an electric fuel pump.
- Deleting the security switch in the glove box.
- Changes to the ground location(s) and/or wire runs.
- Any change from stock for the Otter Switch/Cooling Fan control.
- Electric light pod lifts.
- Changes to the headlight/pod/ sidelight switching if something is worn out.
- Alternator “upgrade” or change.
- Voltmeter.
- Modern radio/ head unit/ speakers / etc.
- Some USB’s or power points to charge a phone, plug in a Garmin, etc.
- Wideband O2.
- Electronic ignition, which might need/prefer an extra power wire.
- Tach electronics upgrade or any required loom changes to accommodate later.
- Whether to eliminate any of the bullet connectors in favour of more modern block connectors. Some of the guys that have Autosparks looms can better describe details, but having easily separated block connectors to allow easier removal of the dash has a lot of merit if the Autosparks wires are long enough? Has to be done in conjunction with loom installation to be able to feed the wires thru the firewall before attachment of the connectors though, so needs to be thought thru.
- Whether to add any relays to lighten the load on various switches.
- Any changes to the stock flasher circuits, including turn signals, emergency flashers abd on some models a flash to pass style feature.
- Delete the firewall mounted voltage regulator completely or modify internally to suit the alternator option selected.
- Upgrade the 10v voltage stabilizer to solid state. This is a small box attached to the tach that provides 10v stabilized supply to the fuel and electrical temperature gauge. Might need a minor local wiring change for the ground.
HTH
Stu
1969 Plus 2 Federal LHD
