Plus 2 wiper motor
Does anyone know if an MGB wiper motor, available from Moss Motors, will fit a 1970 Elan Plus 2? Thanks.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Probably, the only difference being the sweep, easily fixed by swapping the drive plate inside...
yes it will fit but check that it is a 130° drive wheel.
Be careful sometimes wiper motors are sold without drive wheel. to fit yourself
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Thanks, but how do you know if the drive wheel is 130 degrees? The driven gear has 46 or 47 teeth.
67 Elan +2
67 Elan +2
- seniorchristo
HI
Stamped on the gear wheel, you have to remove the cover plate, also note if it stops extended or retarded.
You can change the stop position by moving the plastic clip under the gear wheel.
Can you use your original gear wheel?
Good hunting
Good hunting
+2s130 1971
+2s130 1971
