Fan Controller/Otter switch
Fitted new wiring harnesses to an S4, but cannot find any connections for the Otter Switch and no mention in the Workshop manual. Can anyone advise where to look.
Have a capillary type water gauge so need to find a way to check the temperature and to switch on the electric fan when needed, any ideas on where else I might locate a fan controller, what type of controller and a relay and finally a wiring diagram.
Tony
Tony
- tonyabacus
This one from Burton Power works well. This particular model is used with an M22 threaded boss, fitting in either the radiator top tank or an extended thermostat housing with blanking cap.
https://www.burtonpower.com/revotec-ele ... c-m22.html
Similar kits are available with a radiator hose nipple that can be inserted into the radiator / thermostat top hose. This link shows various sizes.
https://www.burtonpower.com/parts-by-ca ... llers.html
The wiring is pretty simple. This link has the fitting instructions for one of the types, and includes an illustration of the wiring.
https://revotec.com/product/25-mm-id-ho ... ontroller/
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
