Elan S3 S4 Wiring Diagram CAD File
I have made a number of changes to my Elan S3/4 wiring that includes the following:
- Splitting supplies into a number of fused 12v supply circuits (6 permanent, 6 Switched and 4 Auxiliary)
- Adding Battery Cut Off switch (to 12v -ve supply)
- Adding Electric Radiator Fan relay, thermostat and over ride switch (with indicator lamp)
- Adding Reverse lamp switch and combined handbrake/rev lamp warning light
- Adding instrument lights to temp/oil pressure and fuel gauges
- Removing control box ('Dynomator' now fitted so control box redundant)
- Wiring in new fuel pump, inertia cut off switch and fuel pump isolator switch.
I would like to update a standard S3/S4 wiring diagram to show these modifications for my car.
I have access to AutoCAD 2016 (drg or dxf files) and SolidWorks (although 3D prt files probably not required!)
I tried opening the CAD wiring diagrams in the Technical Section but just get an error code.
Can anyone help before I'm forced to start from scratch.
I'm more than willing to share any drawings I produce if it helps others thinking about doing the same thing.
Thanks in anticipation,
Bruce.
Bruce.
- brucey58
brucey58 wrote:pharriso wrote:I have S4 wiring diagrams in DXF/DWG & Coreldraw formats, sent me a PM with your e-mail & I am happy to share.
Many thanks, PM sent
DWGs sent by e-mail, please share whatever you create.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
