Wiper switch getting very hot.
PostPost by: mickmade » Sun Mar 24, 2024 4:08 pm
The wiper switch on my s3 Elan coupe gets very hot.
This occurs when the ignition is on , but the wipers not switched on to work.
Switching the wipers on , makes no difference to the switch temperature still very hot.
Any ideas would help.
Are new switches avalible?
Thanks.
mickmade
New-tral
PostPost by: billwill » Sun Mar 24, 2024 11:59 pm
I suspect that the parking contacts on the actual wipers are not opening properly.
PostPost by: Andy8421 » Tue Mar 26, 2024 1:21 pm
As Bill mentions, the problem could easily be elsewhere - dodgy wiring or the parking contacts, or the motor itself not parking fully.
There were at least two different wiper motors on the Elan, the later model on the S4/Sprint had quite a complicated self park, the earlier motors were more simple.
Which ever it is, unless you are comfortable fiddling with electrics, I would get it seen to before you use the car again. I would also be inclined to remove a battery cable when you leave it parked until it is fixed.
Electrics shouldn't get hot, certainly not when 'off', and as the fusing is virtually non existent on the Elan, fires are a real possibility.
32 Standard 12
Various modern stuff
PostPost by: 661 » Tue Mar 26, 2024 1:47 pm
Andy8421 wrote:As Bill mentions, the problem could easily be elsewhere - dodgy wiring or the parking contacts, or the motor itself not parking fully.
^^^^^Good advice
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: billwill » Wed Mar 27, 2024 11:39 am
Check this topic: viewtopic.php?t=34354&p=234340
And here are two circuit diagrams used for the wipers:
PostPost by: mickmade » Thu Mar 28, 2024 6:20 am
Thanks for the replies.
I will let you know what I find,when delving behind the dashboard.
mickmade
New-tral
PostPost by: Craven » Thu Mar 28, 2024 12:26 pm
You might want to feel the motor to check if this is getting warm may help with where the current is flowing.
Users browsing this forum: No registered users and 47 guests
