Philips Turnolock Spyder Radio
I recently purchases a Philips Turnolock radio off eBay to fit into my Elan. It's a Spyder Delux 22RN513 /22. Am I correct in thinking there should be a red power cable coming out the back? I only seem to have earth and aerial (grey) wires. If so can anybody tell me where the power wire connected to in the radio or even recommend somebody who could fix the radio for me?
Carl
Carl
pereirac - Coveted Fifth Gear
I just checked on a 314 lying around, and the red wire was getting out from the hole just next to the loudspeaker output (NB: female, but you have prongs/connector blades stuck in on your photo).
I've circled on your photo in red and black the opening from which the red and black wires would be getting out
I suppose your radio has been opened and "fettled" with, as I'm sure you've noticed when you removed the casing... I can check an actual 513 if it matters to you, but what I woud to would be at least to double check where each of these wires are soldered internally.
I believe the aerial would have to be plugged in an outlet to the other side (the grey wire may be to light up the screen, again I can check if you need).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
The 2 pin speaker prongs just pull out and I have another speaker plug I can use.
I sort of guessed the main power lead was missing but don't know if this is because it was pulled off or if somebody messed around with the wiring?
The second photo shows where the other wire are soldered. I just don't want to blow anything up by connecting 12v across the grey and black wires The aerial socket is all fine and looks ok.
It would be nice to get the radio up and running again
Carl
Carl
Carl,
I used a company called radio rescue. Eric Capron is the man. [email protected] phone 07802242242
I have been very pleased with what he did for me.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Carl,
The grey wire is for an electric aerial, black is earth. Your red wire has most likely been pulled off.
Have a poke around the area that I have circled in red. If you can see where the end of a wire has broken off and you feel adventurous, you could try soldering a new wire to this point.
It looks a likely spot, that wire wound component below this is an inductor and would have filtered the incoming power supply to reduce interference.
This is only a guess, if you don't want to risk it, then go to a specialist.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
pereirac wrote:Thanks,
Carl
Well, if you need I can dig a 513 and open it to take a photo of where the power wires are soldered (as for the aerial, on the radio of that era that have a grey cable with a female outlet at the end rather than a female plug in the middle of the casing, this is a thick coax cable, 4-5mm in diameter, so I would double check where this one goes before assuming this is for the antenna).
S4SE 36/8198
Two different people have come back to me and suggested that’s where the missing power cable goes, so I will give it a go! Thanks for all the advice!
Carl
Carl
pereirac wrote:Two different people have come back to me and suggested that’s where the missing power cable goes, so I will give it a go! Thanks for all the advice!
Carl
Carl,
Good luck. To give you a bit more confidence, this seems to be the same model as yours....
32 Standard 12
32 Standard 12
- Andy8421
Hello Carl
I have a couple of Turnalocks being looked at by the guy on the TV programme, Repair Shop, he is not a million miles away from you up in Cromer.
His details are:
Mark Stuckey
212 Roughton Rd, Cromer NR27 9LQ
Phone: 01263 519278
website: https://www.classicradioshop.info/
His details are:
Mark Stuckey
Phone: 01263 519278
- tonyabacus
