tail lights
PostPost by: street » Tue Nov 28, 2023 8:53 am
I have no tail lights or number plate lights, brake lights, reverse and indicators all work, bulbs are good all fuses appear okay.
Appreciate any help, electrics are not my strongest. Assume i start at switch on dashboard, position 1 and 2 both work for headlights.
thank you
street
PostPost by: 661 » Tue Nov 28, 2023 9:35 am
Assuming Elan, it may be the connector under/around the glovebox that splits the feed from the switch to the front and back looms, with just the rear connector coming out if the sides still work. There is another split in the rear loom, but I find the front interior bulkhead the one most likely to fall out. Solid red wires if I recall.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
