Tachometer conversion company in US
PostPost by: gjz30075 » Sat Sep 02, 2023 11:52 pm
Does anyone in the US know of a good company that can convert an S3 tach from positive ground
to negative ground? Points will be used. I know about MoMa and Nisonger (whom no longer fixes
instruments, as far as I know).
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: gsilvestri » Sun Sep 03, 2023 1:01 am
British Speedo Service https://www.britishspeedo.com
gsilvestri
New-tral
PostPost by: elancoupe » Sun Sep 03, 2023 1:13 am
It’s been a few years, but I used West Valley Instruments in California, they converted to negative ground, and also for electronic dizzy.
elancoupe
PostPost by: ElanDNA » Sun Sep 03, 2023 10:06 am
gjz30075 wrote:Does anyone in the US know of a good company that can convert an S3 tach from positive ground
Do it yourself. A few minutes of fear and it's done. :lol: :lol:
https://www.youtube.com/watch?v=ddZ0E2Wd6Ic
tach12s.jpg and
PostPost by: steve lyle » Sun Sep 03, 2023 12:04 pm
elancoupe wrote:It’s been a few years, but I used West Valley Instruments in California, they converted to negative ground, and also for electronic dizzy.
West Valley did mine as well.
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: gjz30075 » Sun Sep 03, 2023 6:43 pm
I like the options here. Thanks much everyone!
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: billwill » Tue Sep 05, 2023 6:51 pm
Its a trivial alteration, just need to swap over the positive & negative wires inside the can.
Any hone electronics bloke could do it for you.
PostPost by: steve lyle » Tue Sep 05, 2023 6:59 pm
In addition to the polarity change, have the tach changed from current sensing to voltage sensing. Much more accurate, and quicker response. WV did this for me. If you go this route you also need to run a sensing wire from the - coil terminal to the tach.
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: gjz30075 » Tue Sep 05, 2023 7:22 pm
Good points here. This tach is currently positive ground and set up for pertronix, whatever that means.
Sounds like West Valley for the win here.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
