S130 mystery warning light fault
PostPost by: checkrail » Sat Jul 15, 2023 4:00 pm
I'm still trying to solve the fault with my brake warning light on my '71 +2 , it's a three fuse box model. The P.O. has removed the fail safe system, I just have a normal cap on the master cylinder but when I turn the battery isolater switch on,. the red fail light shows on the dash, but turning the ignition switch on to the start position deletes it.
Everything else electrical is working as it should, I have removed all the under dash trim, searching for a possible earth or wire fault but no luck.
The last time I drove the car it was perfect, it baffles me as to why this should happen sitting in the garage, luckily that I have a battery master switch.
I would really appreciate some help with this annoying problem
Thanks very much John
checkrail
PostPost by: JonB » Sat Jul 15, 2023 5:57 pm
I’d pull the bulb.
PostPost by: checkrail » Sun Jul 16, 2023 8:27 am
If I pull the bulb there's an outside chance that I could forget to turn the master switch on.
Result flat battery?
checkrail
PostPost by: JonB » Sun Jul 16, 2023 9:08 am
I doubt that. Unless you have an electrical fault (in addition to the lamp) that causes the car to draw power when the ignition is off.
Anyway, proper diagnosis is the correct action here. You’ll need to trace the wiring with respect to the wiring diagram for your car. IIRC the indicator wires exit the loom under the master cylinder. I wonder if they are still there, maybe loose and shorting against something?
PostPost by: checkrail » Sun Jul 16, 2023 2:53 pm
I have found the wires buried under the master cylinder, they have good insulation with 12v at the terminals.
There is no sign of any shorting, the wiring diagram shows a connection with the heated rear screen which is fine.
I will struggle on.
checkrail
PostPost by: Donels » Sun Jul 16, 2023 3:05 pm
The warning light comes on when the fluid level is low. This happens when the contacts in the SOVI connect, so if the PO removed the SOVI and connected the wires it will be on.
Elan +2
Elise mk 1
PostPost by: checkrail » Sun Jul 16, 2023 5:35 pm
I have owned and used the +2 for four years now and this has only just happened, so this is what the mystery is as nothing has been altered.
Why does the light go out when the ignition is switched to the running position?
checkrail
PostPost by: billwill » Sun Jul 16, 2023 10:16 pm
checkrail wrote:I have owned and used the +2 for four years now and this has only just happened, so this is what the mystery is as nothing has been altered.
It's weird but what you are describing is, I think, the standard behavior of an alternator's charging light.
PostPost by: JonB » Mon Jul 17, 2023 8:29 am
Not quite. The alternator light goes out when the engine is running and it is supplying electrical power, not when the ignition is turned to the running position (actually, that's when it comes on).
PostPost by: Spyder fan » Mon Jul 17, 2023 9:30 am
Jon, the OP states the brake warning light comes on when the battery isolator is switched on, but goes out when the ignition is switched on. So there is obviously an open circuit present that is closed when the ignition is switched on.
Kindest regards
Alan Thomas
Spyder fan
PostPost by: Spyder fan » Mon Jul 17, 2023 10:27 am
I think that Bill is on the right track in that failing alternators do all sorts of strange things to vehicle electrics. When my own alternator failed the ignition light remained on when the ignition was switched off, which is a common symptom of fried components in the alternator. Looking at the wiring diagram for an S130 I can see that the Sovy and warning lamp are in the same circuit as the ignition.
I’m guessing that this can be tested by disconnecting the alternator…. Bill?
Kindest regards
Alan Thomas
Spyder fan
PostPost by: checkrail » Mon Jul 17, 2023 11:52 am
Thanks for all the comments, of the two wires of the warning system the earth goes to the solenoid earth on the bulhead and the + wire goes down into the harness towards the front of the car. I presume it ends up at the centre fuse box
As I have already commented the heated rear screen which is on the same feed is working correctly
checkrail
PostPost by: checkrail » Mon Jul 17, 2023 1:08 pm
I removed the fuse for the warning light/ rear screen, but the fault is still the same but no power for the screen.
I pulled the plug on the alternator, that's made no difference.
There's power getting to that light from somewhere?
checkrail
PostPost by: billwill » Mon Jul 17, 2023 2:27 pm
It's possibly getting power THROUGH another bulb somewhere that is not earthed properly.
PostPost by: checkrail » Mon Jul 17, 2023 3:43 pm
Thanks for the suggestion, that will keep me busy!
checkrail
Next
