ignition switch 72 s130 federal
Trying to sort out some of the electrical/dash stuff. This is a project car that i recent bought. when loading on the trailer noticed that the ignition switch spins when turning the steering wheel. there does not seem to be a way to detach it /loosen it. it clamps to the column but i cant see a way to loosen it as there is no screw or bolts to loosen. both are "buried" in the clamp it self. any info would be helpful , thanks.
- koobs90
From the factory they have snap off fittings. So if there no heads on the bolts they have been snapped off and you'll need to drill the out it find a different solution.
Likely best to remove the entire columns from the car.
- mbell
With respect to snap of bolts holding the switch/lock to the steering column, I have had success using a small chisel and hammer to unscrew the bolts.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
figured it out, original owner found the keys and... keys fit and unlocked ignition safety, bingo
- koobs90
