Failsafe headlamp spring fitting
I've abandoned the electric lift conversion on the car and now in the process of reverting to original failsafe vacuum lift. All was going well until it came to installing the lift springs. I have a new smaller/softer one from SJS which went on OK on one side but the full strength original spring is resisting all attempts to fit the other side. Basically I cannot bend it enough to fit the mounting holes and I've tried top first and bottom first but its just not going to happen. Has anyone experience of this and found a trick to it ?
Thanks, Mike
Thanks, Mike
Elan S4
Elan Plus 2 JPS
MR2turbo
Elan Plus 2 JPS
MR2turbo
- 2tmike
Well done to keep vacuum system.
For the vacuum unit i imagine you have the fitting to go between the car body and vacuum unit.
Is it easier to fit tje loop in the spring to pod and vacuum unit. Then lift vacuum unit fitted to spring bent end into place compressing spring. Attach vacuum unit to body.
All this with no light units in place
- alan.barker
Well done that man, keep up the good work.
- alan.barker
