S3 dash light
Hi all, my S3 Coupe has the dashboard light with the on/off slider switch and works fine except I
found the repro lense and chrome 'hood' doesn't fit well at all (see pic). The lense and chrome
hood are from a non switch light because I can't find a switched light. What is the source of the
switched light?
switched light?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Greg,
I think your photo shows a courtesy light from an MG B.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
This switch has the slider knob on top and it works in conjunction with the three toggle switches
below it for the various modes of lighting needed. The bottom measures 4 7/8 inches across.
It has two purple/white wires and a ground.
PM sent to Batfish
PM sent to Batfish
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
Thanks for the tip on Holden's. They do have one for an MGB (I see Richard's thinking now) but it does not
have a ground wire (not sure how that would work with the Elan wiring) and it's out of stock. I'm
just putting the dash back in now and when the wiring is complete, I'll pull the ground wire off and see if
it works.
it works.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
Greg,
You might try Kelvedon for the light. I think I purchased a couple from them to use for my S3 coupe for rear quarter interior lights. They do have the sliding switch on them, which I believe in not correct for the rear quarter courtesy lights, but that's what I bought because the ones without switches seem to not exist. Where did you find it without switch?
Eric
Eric
Life's too short to drive boring cars!
'66 S3 Elan Coupe'
'66 S3 Elan Coupe'
- Bushwacker
