Tachometer wiring
I removed the tachometer from my S4 some time ago prior to tydying up the wiring and fitting a new dashboard. Putting the new dashboard in, so far so good. The tachometer has two white wires coming out the back one of which goes to the ignition switch and the other to the security switch, but which goes where? Does it matter?
Attached pic shows back of tachometer with wires labelled A and B, can someone tell me which is which please.
The top of the tachometer is to the right of the image.
1969 Elan S4 FHC, purchased in 1978, now with a big valve engine.
- JohnMorin
Hi John,
Although my car is an S3, I thought the white wires were fairly short so that the Tachometer could be removed easily. It does matter which way it is connected and I think one wire had a male bullet and the other a female bullet connector. It will not cause any damage if incorrect, it just will not work.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Ah, that`s not very helpful then.
However if you can get access to it easily just connect it as seems most likely. It is a 50% chance it will be right.
If not, then the current pulse into the tach will be reversed and the system will ignore it but will not be damaged.
Eric in Burnley.
Eric in Burnley.
- ericbushby
ericbushby wrote:Hi John,
I think one wire had a male bullet and the other a female bullet connector. ...
1967 S3SE DHC
Yes, my Tacho connections look like:
Not sure which connection went where though sorry...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Often worth searching the MG forums for these things. They have the same problems as us, but there are more of them....
Ignore the comments in the bubbles, its large black and red writing you need to follow.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Users browsing this forum: GaryE and 20 guests
