Temp Gauge Electric Version +2S
Anyone know if the wiring connections to the back of the temp gauge requires to be specifically connected. Can they be connected the wrong way
Breezehill - Second Gear
I’ll need to get behind the dash, possibly tomorrow.
Hello, not sure if it helps.Taken off the wiring diagram +2S non federal, it looks like the light green is the feed in to the temp gauge on all the diagrams. On my +2s130/5 the light green feed in, is on the left spade as you look at it from the rear of the gauge. Regards Steve
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
I was in a rush last night and should have elaborated more - you do not say what gauge you have. Only if the gauge is marked at each terminal with an I or S, or maybe + and S, is it critical (S is to the sender and the I or + is a switched 10V) If you have a later Smiths type, then there are no markings so the connection is not critical. But make sure the body is earthed for the panel light.
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
Hi everyone
Thanks for all your help, just need some time to check out your thoughts. I’ve found all the photos I took of the dash from the rear and can see looking from the rear the light green on the left spade.
The new loom replicated the connections.
