alternator for lhd ?
PostPost by: Mike Spence » Mon Aug 15, 2022 3:34 pm
Hi, I bought an alternator from Sue Miller (powerlite RAC056) several years ago + alternator fitting kit of Kelvedon.
Now, I want to instal this alternator, but now I determine that its too big on my lhd Elan S3.
There is not enough space, and it hits the steering column ! See the pictures.
Is there anyone who can help me to solve this problem? Or which is a good alternative ?
Many thanks, for helping me.
Michel (from Belgium)
IMG_0811.JPG and
IMG_0810.JPG and
Mike Spence
First Gear
First Gear
PostPost by: steve lyle » Mon Aug 15, 2022 4:05 pm
Both RD Enterprises and Dave Bean Engineering in the US sell alternator conversions that fit. I believe the use 35 amp Nippondenso alternators. Not sure. What model, or what other cars it’s on.
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: snowyelan » Mon Aug 15, 2022 4:19 pm
I was told by an alternator shop that the 35A denso was used on towmotors/forklifts.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: prezoom » Mon Aug 15, 2022 4:25 pm
I got both my Denso alternators from Suzuki Swift/Metro Geo at the local Pick A Part. Both were 55amp. DUI in the US also sells Denso 55amp alternators converted to one wire operation. I used those on my race engines. Small, and weigh about 6lbs. If you do use the junk yard approach, be sure to also take the wiring connector from the wiring harness, makes a nicer/easier installation. These alternators are also used on small tractors, Kubota, etc., but at a lower amperage. I went with the 55 amp versions because of electric fans.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: HCA » Mon Aug 15, 2022 5:18 pm
As already said - the Denso is the only way. Much better than Powerlite and is lighter. You will be fine with a 40 unless you are running serious rally lights. If though you have 250€ to burn, Denso have recently launched a very natty lightweight two wire 50A version…
Denso only has one mounting lug, so you will need to pack out the mounting bracket. Or better, make a new one to suit.
Did you specify lhd when you purchased the Powerlite?
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: pharriso » Mon Aug 15, 2022 9:46 pm
This is what I bought when my RDent supplied alternator failed : https://www.amazon.com/gp/product/B00KL51IM8/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1, cost is $85
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: pharriso » Mon Aug 15, 2022 9:51 pm
Mike Spence wrote:Hi, I bought an alternator from Sue Miller (powerlite RAC056) several years ago + alternator fitting kit of Kelvedon.
For the record, LHD cars had a different alternator mounting bracket to avoid this exact issue. Search on here & you'll find info, though I am sure the LHD bracket is very difficult to find & the Denso alternator is the way to go.
Phil Harrison
PostPost by: mbell » Mon Aug 15, 2022 9:54 pm
I think this is the one I fitted to my (RHD) car: https://www.amazon.com/dp/B0081SB17E/
Works well, I need need to add a switch live connection for it with it being a 3 wired alternator.
PostPost by: rgh0 » Tue Aug 16, 2022 2:53 am
There was a different bracket for the LHD cars with an alternator to lift up the alternator a little to enable the large Lucas alternator to fit. Not easy to find these days and the smaller Denso alternators can fit as others have said
