Removing Lock Barrel from steering Column Lock
Does anyone know how to remove the lock barrel from a Sprint steering column lock?
I have the key, but can’t see an easy way of removing the lock barrel.
The lock barrel is well worn, hence my desire to replace with a new one. That being said I can see distinct advantages of replacing it with a dash mounted ignition switch.
71 Elan Sprint FHC Pistachio
36/0262E
36/0262E
- Bodmin
Is there a circlip holding the barrel in its tube?
billwill wrote:Is there a circlip holding the barrel in its tube?
Not that I can see.
36/0262E
36/0262E
- Bodmin
Subscribed
I have 2 spare Waso ignition locks, 1 without a key & 1 with a key & would like to know how to dis-assemble myself so I can clean the lock / re-key them.
I suspect that the 2 roll pins circled below are involved somehow:
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Bodmin wrote:The lock barrel is well worn, hence my desire to replace with a new one. That being said I can see distinct advantages of replacing it with a dash mounted ignition switch.
Like what? You would lose the steering column lock...
Phil Harrison
pharriso wrote:Bodmin wrote:The lock barrel is well worn, hence my desire to replace with a new one. That being said I can see distinct advantages of replacing it with a dash mounted ignition switch.
I would wire a conventional switch on the dash as per S4. Never liked fumbling around with the steering column lock. That being said I could re-install the mechanical parts of the steering column lock to give the option of locking the steering.
However..I believe more steering column in/out adjustment is available if there is no requirement to engage the lock into the upper column. Another benefit would be less clutter making it easier to access various items in that area behind the dash.
36/0262E
36/0262E
- Bodmin
Does anyone know which car the steering lock was originally made for.
Searching internet forums for that car might be useful.
billwill wrote:Does anyone know which car the steering lock was originally made for.
Good idea, but I haven’t uncovered the mystery yet! No idea which car it was manufactured for. No success on the Triumph forums either.
36/0262E
36/0262E
- Bodmin
I have just had a search too without luck. Triumph TR6 later version seems the likeliest candidate.
I found that a lot of steering locks are made by NIEMAN, but did not locate one that looks like your picture.
If the roll pins shown in one of the postings above are evident (or a little hole in those kind of locations) try pressing both simultaneously with a pointed object with the key in the lock, rotate the key to see if there is a point at which the pins depress. If that happens pull the lock barrel out through the front ?
Also used on E-Type Series III, there's a bit of info here - https://www.google.com/search?q=waso+ignition+lock+site%3Aforums.jag-lovers.com&rlz=1C1CHBF_enUS953US953&oq=waso&aqs=chrome.1.69i59l2j46i131i433i512j0i131i433i512j0i512j69i60j69i61j69i60.5060j0j7&sourceid=chrome&ie=UTF-8
But no cigar
Phil Harrison
billwill wrote:I found that a lot of steering locks are made by NIEMAN, but did not locate one that looks like your picture.
This lock was made by WASO
Phil Harrison
Some success to report.
I used a rotary wire wheel to remove the paint around the two small holes which revealed it is indeed two tiny roll pins that we’re dealing with. Obviously they’re not designed to be pulled out, so on that basis I pushed them in a few mm using a 1.5mm punch. This allowed the gubbins to be released.
I haven’t gone further yet, but at least I’m back into more familiar territory.
36/0262E
36/0262E
- Bodmin
Awesome! Well done that man!
I was about to try drilling them out, pushing them in further is much easier
Will try to reproduce your success a little later.
Phil Harrison
Just as a small reminder to anyone embarking on this project (myself included), there is a very small pin which falls out while removing the barrel.
I only discovered it after the event laying on the workbench. The pin is approx 1.5mm dia x 5 mm long. It is a pivot for the lever which controls the locking shaft.
36/0262E
36/0262E
- Bodmin
