tachymeter Elan S3
I need to replace my Elan S3 Tachymeter which looks like the +2 except for the colour of the inner dial which is mouse grey.
I would like to know the correct part number of the original. Who can help me?
For the black inner dial, is there a specialist who can reproduce it? What would you do and what restoration facility would you recommend?
geni without the final "e
- geni
I would ask them first:
https://www.smiths-instruments.co.uk/lotus/elan
about ordering just the face
Does it need repair or does it work correctly ?
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC
1969 S4 FHC (worn engine)
1967 S3 DHC
- gherlt
Geni,
most specialists that do instruments have the ability to print new dials. So if you only need a different ‚face‘, it should be straightforward. I can recommend a shop close to Cologne, that has done work for me, but I am sure that you will find local specialists. Converting my S3 MPH instrument to KMH including revision was €350,-. Unfortunately, the speedo drive in my 5 speed box failed soon after. As this is TÜV/ contrôle technique sensitive and the replacement of the speedo drive requires engine& gearbox removal for the Elan, I had to go for a new, electronic Smith replica tach. These are only available in MPH, so a new dial is on the wish list…..
Philipp
Philipp
- Attachments
- 98EC3F69-7C6E-4732-B659-DFE30043302A.jpeg (66.63 KiB) Viewed 253 times
- phil1800
Or, you can have a little fun and print them yourselves.
https://www.blocklayer.com/gauge-templates.aspx
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
45/0243K Sprint
gjz30075 - Coveted Fifth Gear
désolé de relancer ,mais n'y a t'il vraiment personne qui peu relever le numéro (situé sous l'aiguille du tacho ) ?
et si vous posséder un doublon serait aussi intéressé a l'achat
Merci de partager
geni
Merci de partager
geni
- geni
