Lotus Elan
location of indicator relay for plus2 130/5
PostPost by: kepig » Fri Jun 17, 2022 9:15 am
Hi there can anyone help as to the location of indicator relay on a plus2 130/5 manual says behind drivers window switch but there is nothing there . the left side flashes but the righthand side just lights up but no flashing any help would be most appreciated thanks Jude
kepig
New-tral
PostPost by: mbell » Fri Jun 17, 2022 6:33 pm
The flasher unit is fasten to the rear of the dash around the speedo area if i remember correctly.
However the same unit drives boths sides. If it works on one but not another it likely a fault in righthand side causing it not to work. Bad bulb, wiring fault or something.
PostPost by: Steve Brooks » Sat Jun 18, 2022 7:48 am
Hello, as mbell states, mine is not fixed and is behind the dash just to the left of the steering column. Put the indicator that works on and you should feel the relay working.
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
Steve Brooks
First Gear
First Gear
