What battery fits the original tray?
PostPost by: sprintsoft » Sat May 28, 2022 2:19 pm
..time for a new battery...
for an Elan Sprint with the original battery tray on the left side in the boot, what would you all reccomend that fits that space correctly so I can use the original clamp?
I have round terminal posts...
Thank you!
Iain (UK based)
72 Sprint - 0363E
74 S130/5 - 1931L
sprintsoft
PostPost by: Craven » Sat May 28, 2022 2:56 pm
I had to settle for this one for size and bottom fixing, but check if your leads will go with left hand positive terminal. Very good battery and price don’t think you will find better.
https://www.batterymegastore.co.uk/prod ... er-battery
FWIW
PostPost by: elanfan1 » Sat May 28, 2022 3:49 pm
Original was an 037 square posts.
PostPost by: sprintsoft » Sat May 28, 2022 4:01 pm
Hi Craven,
my positive lead won’t make that stretch unfortunately…
Elanfan1,
yes I used to have the 037 many years ago… do you have the dimensions by any chance?
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
sprintsoft
PostPost by: draenog » Sat May 28, 2022 8:03 pm
I use a type 038 in my +2, which is the same size as a 037. The difference is it has round posts instead of the square ones. They're also reversed, but I just turn the battery round to face the other way...
Type 037 245x135x200
https://www.tayna.co.uk/car-batteries/enduroline/037/
Type 038 245x135x200
https://www.tayna.co.uk/car-batteries/enduroline/038/
draenog
PostPost by: sprintsoft » Sun May 29, 2022 1:19 pm
Thanks Rob,
I think I'm going to convert back to the flat 'Ford' type terminals and use that 037 you showed ...
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
sprintsoft
PostPost by: GLB » Mon May 30, 2022 8:03 pm
I don't know if this applies to series 3 and 4, but I needed a battery for my type 26 series 1 last year. I went to my battery dealer to order a Miata sized battery which I have been using. $115 and needs to be ordered. He offered me a lawn and garden tractor battery. Exact same width and depth, maybe 3/4 inch shorter with flat terminals. CCA and AH rating just slightly lower than Miata battery. Sealed style. same warranty. Gave me new battery terminals to crimp onto welding cables I use for battery cables. $47 Posts available either way. It is only one year old now but but has given perfect service so far. You might check as price difference is significant. Gary
GLB
PostPost by: sprintsoft » Tue May 31, 2022 7:57 am
Thanks Gary, I hadn't thought of that as an option, I'll see what I can find... Iain
72 Sprint - 0363E
74 S130/5 - 1931L
sprintsoft
PostPost by: elans3 » Tue May 31, 2022 10:21 am
Found it easy to sort on my S3 (pos earth), bought an 038 round post, fits perfectly. For neg earth just turn it round.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
