Alternator Bracket Arrangement
PostPost by: 111Robin » Tue Feb 01, 2022 8:23 pm
Can someone please post a photo showing how the alternator strap and bracket should be fitted, plus 2 if it is different. I get how the forked slotted bracket fits (item 20) but the additional plate with three holes (item 21) is confusing me. How is this arranged on the engine ?.
20220201_202551.jpg and
111Robin
PostPost by: ncm » Tue Feb 01, 2022 9:21 pm
Hi, Item 21 is fitted to the rear of the timing chest, attached by the through bolts. See pictures I posted here :- viewtopic.php?t=16002&p=80454 .
Cheers, Brian.
PostPost by: 111Robin » Tue Feb 01, 2022 9:49 pm
Ok, so the bolt that passes through the forked end also passes through the centre hole of item 21 ?. Difficult to make it out on the photos.
111Robin
PostPost by: ncm » Tue Feb 01, 2022 9:57 pm
That's correct.I believe the idea of the plate is to brace the lug on the covers to stop it breaking off.
Pictures not easy to take when installed in the car!
Brian.
PostPost by: 111Robin » Tue Feb 01, 2022 10:23 pm
Thanks Brian, this plate was missing when I removed the alternator hence the confusion. I think I understand the arrangement now.
111Robin
PostPost by: nmauduit » Wed Feb 02, 2022 9:51 am
some detail photos can be found on the forum, e.g.
https://lotuselan.net/forums/viewtopic.php?f=38&t=38341&start=
S4SE 36/8198
PostPost by: rgh0 » Wed Feb 02, 2022 10:05 am
Note in the photo above the arm itself is not the Lotus original which was straight and not curved and of much lighter construction but did mount in a similar way to the triangular bracket on the 3 front cover bolt holes
PostPost by: 111Robin » Wed Feb 02, 2022 10:17 am
Thanks, that makes it very clear.
111Robin
Users browsing this forum: jebracing and 8 guests
