Odd failsafe headlight behavior
My headlights tend to stay down, even when vacuum is removed, until I hit a bump. At speed, it can take quite a jolt to get them go come up, as the drag tends to push them down. It's gotten to the point where, if I think I'm going to need the headlights, I'll raise them before a drive by manually pushing down on the rear edge of the pod before I get in the car, then pull the vacuum switch immediately after starting the engine.
Any idea why this is, and how I can fix it?
The good news is that this is the "last" functional issue I've got with the car (knock on wood). We just got back from a 600 mile drive, and besides this headlight issue, the only other nit was a vibration of the trim around the radio, since fixed with a bit of butyl rubber behind the trim.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
The headlamp pods pivot on bolts in threaded bobbins in the body ... it sounds like the threads may be partially siezed.
You need to remove the headlamps from the pods to gain access to the pivot bolt heads then you can remove, clean the threads and grease them liberally before refitting. I would suggest removing/refitting one at a time then you won't lose the lateral adjustment of the pod in the body aperture.
If the pivots are moving freely then it may be the lifting spring on the vacuum actuator has become weak and needs replacing. The failsafe system uses a different spring from the non-failsafe system .. maybe the wrong spring has been fitted at some time?
S4 DHC
S4 DHC
- oldelanman
Steve, are you sure everything is assembled the right way?
I used to have similar issues, after looking on here I found mine was not & was binding where the spring attaches to the vacuum actuator. I re-assembled correctly, greased everything, added a captive nut & everything works reliably now.
Here are some pictures post-rebuild:
No idea why the pictures are suddenly upside-down!
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Thanks, guys.
Must be a weak spring. The pivots are fine, at least they seem that way after the pods rotate maybe 20 degrees. It's that first 20 that's a problem. A weak spring is the likely culprit, since it looks like the assembly is correct.
I'll go searching for a replacement spring.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
It's the curse of modern technology
![Very Happy :D](https://lotuselan.net/forums/images/smilies/icon_biggrin.gif)
So if the original file is wrong orientation when you upload it here, it displays the original orientation.
Hello, on my failsafe pod there are two springs ( which I believe is normal).One spring on a failsafe will not push the headlamps up on its own.Regards Steve
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
Steve Brooks wrote:Hello, on my failsafe pod there are two springs ( which I believe is normal).One spring on a failsafe will not push the headlamps up on its own.Regards Steve
The OP has a Sprint and your car is a Plus 2... they appear to be different.
According to the Parts List the Plus 2 failsafe system uses two springs but the Sprint has only one. They both use the same vacuum actuator however and you can just about see the holes for the second spring in Phil's photo so you could easily add the second spring if you need to. There are four different springs listed (two LH and two RH) so I presume a stronger version was introduced with the failsafe system.
S4 DHC
S4 DHC
- oldelanman
