Securing the instrument warning light shroud
A picture will save a thousand words
This black shroud usually has a couple of brass-like clips that hold it in and have disintegrated.
Does anyone have a source of replacements or other good ideas, please?
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Graham was actually talking about the spring clips that retain the bulb holder in the back of the instrument.
I have never actually seen any for sale anywhere. You could try making a replacement out of piano wire or even an old clock spring or maybe purchase a scrap speedo off e-bay to harvest the clips? Maybe a bit of heat shrink to increase the diameter to make it a push/force fit?
You could try a wanted ad on here for the bulb holder.
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
lotusfan wrote:Graham was actually talking about the spring clips that retain the bulb holder in the back of the instrument.
ok ... as for bulb holder, maybe something can be hacked around one of these (no affiliation) :
https://www.autoelectricsupplies.fr/product/458/category/81
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Correct. The black bit hasn't crumbled yet.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
nmauduit wrote:lotusfan wrote:Graham was actually talking about the spring clips that retain the bulb holder in the back of the instrument.
The bulb is a smaller size, but I wonder if I could harvest the inner ring of clips and put that on the black shroud???
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
I had the same problem. First try was to hot glue it place. Lasted a while but failed when I removed the indicator bulb. Second try was epoxy it to the case. Worked well. Final fix was sending the speedo out for repair and asking for a fix. Don't know if they added the metal clips or a new piece. Mo-Ma manufacturing, Albuquerque NM. Good repair and very fast, no affiliation. Gary
- GLB
