RPM at a true 60 MPH
• Page 1 of 3 • 1, 2, 3
Hope everyone had a good weekend. I am hoping to get some feedback on what you were 60 mile an hour RPM is to see if my tack is as optimistic as I think it may well be.
Ideally hearing from an S4 owner running standard height modern tires would be great
Thank you
(And man, this thing is a hoot)
Thank you
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
Can you supply the following?
Tire size
Diff ratio
Tire size
Diff ratio
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
For the princely sum of £7.39 plus 99p postage, you can buy a digital tach unit that just needs a pickup wire wrapped around an HT lead to work.
Just search on eBay for:
Digital Tach Hour Meter Tachometer RPM Counter For Snowmobile Motorbike Skis#
There are equivalent models available on the US eBay site, just search using the above text.
It has the advantage that when you have checked the accuracy of your tach, you can fit it to your lawnmower.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
My slightly flippant reply was actually meant in good faith. Checking your tach against a speedo of unknown accuracy with tyres of unknown rolling diameter is never going to be a precise business.
To improve things, you could put a chalk mark on the tyre and measure how far (say) 10 revolutions gets you letting the car roll forwards. You could also use a GPS speed app on your phone for speed.
Depends how accurate you want to be. In a past life I did measure the rolling diameter of a number of tyres of supposedly the same size from different manufacturers and there was significant differences (up to 10%).
For the price of one of those digital tachs (I bought one myself) you can at least have some faith in your measurements.
32 Standard 12
32 Standard 12
- Andy8421
The diff ratio on a US S4 should be 3.77.
If that is what you have then, with the tire size specified, you should be at 3340 rpm at 60 mph, assuming both your tach and speedo are accurate.
This is ignoring higher order effects such as tire inflation, tire wear, tire heat, load, ... Also, the presumed 80 profile might not be that accurate either.
If one uses the more precise diff ratio of 3.7777777... (34/9) instead of 3.770, for example, the rpms at 60 would be 3345 instead of 3340.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Thank you, that’s very helpful. I expect the supplemental digital tack that I ordered today to confirm this tomorrow. It does raise the question of why my current unit is reading anywhere between 1000 to 1500 RPM high.
Appreciate the details and response.
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
What you ignition setup? Have you gone electronic?
Two likely hoods if missing reading:
1) Electronic ignition causing more current pulse being picked up by tacho
2) Capacitors in tacho are failing due to age causing miss readings
- mbell
Yup, try powering straight from start solenoid instead of the coil to test. If that sorts it a simple fused relay, using coil to switch it and solenoid as power source should sort it out.
- mbell
1969 S4 SE with 155HR13 XAS tires, standard diff
60 mph 3300 rpm =/- no markers between 3 and 4 so estimating.
At 3000 rpm, speed is 53 mph
Looking at the two gauges while driving in 4th gear, speedometer and tach, the needles should be in line with each other on their respective gauge - same position on each gauge.
That's the simple way to tell if your tach is accurate.
- m750rider
