Stranded for Christmas
Hello and greetings of the season to all.
Short story: I have a non operating starter, solenoid clicks but no action from the motor. Starter has about 300m on it from replacement . The lights stay bright when I turn the key. I have battery voltage at the positive side of the solenoid and about 0.6v less on the starter side when trying to crank (tested with the meter on the solenoid pole and engine). When I operate the solenoid the voltage across the pins drops to zero. I tried shorting across the solenoid with a jump lead and there was no effect. The engine can be turned over by pushing in gear and I can turn the starter with a spanner on the end shaft. Does this sound like the starter is dead?
Long story: Car has been with Paul Matty for a while this summer and they reported an intermittent issue that the starter solenoid just clicked sometimes but usually resolved itself second try. After getting the car back I had no such issues and put it down to a lack of use before it went to PM. As the weather has got colder I have found the engine rather sluggish to start which I would normally put down to cold oil but on Christmas day the engine barely turned over despite only last being used 10 days previously. It caught on the last gasp from the starter and off we went. I was uncomfortable doing this as I have bust a tooth off a bendix in the past in a similar situation but when I reached my destination I switched off and restarted no problem. When I tried to start it later I just got the click. I tried all the checks above, took the solenoid off and warmed it up a bit (desperate), charged the battery but to no avail. The starter is a remanufactured Lucas unit from Powerlite and although it has been on the car for 18 months or so has only been driven for about 300 to 400 miles and churned a bit while doing compression tests so I would have thought it should be ok. I haven't done the shorting across the solenoid poles before but assume it should spin the motor when doing this with the ignition on regardless of the solenoid failing or not(?).
Any ideas?
Robbie
Any ideas?
Robbie
I have run two ground wire to my chassis, one from battery ground, one from starter bolt.
Is it more moist out these days. Could condensation be hindering contacts.
Love your Mother
Earth
Love your Mother
Earth
First thing I would do is try a known good battery
George
Elan+2
Mk2 Mx5
Elan+2
Mk2 Mx5
- George S L
Robbie693 wrote:Hello and greetings of the season to all.
Yes - assuming that the two events in bold above can happen simultaneously. There is always the possibility that the engine earth has broken / fallen off, but your - "I have battery voltage at the positive side of the solenoid and about 0.6v less on the starter side when trying to crank (tested with the meter on the solenoid pole and engine)" - test would indicate that the engine earth is OK. I would suggest you take the starter off and check it on the bench.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Some more suggestions here
viewtopic.php?f=38&t=45329
I rewired my starter circuit as suggested, as it was wired straight through the ignition switch. I am now using the redundant solenoid on the bulkhead as a relay to trigger the starter motor feed. I have only done a few miles since so can’t comment on whether it has solved my intermittent starting problems.
Lotus Elan Sprint FHC 1973
RichardS - Fourth Gear
Hi Robbie,
maybe if you remove the Earth Screw in the Boot that goes through the Chassis.
Remove completly from Bobbin as this clamps to the Chassis for the Earth. Good clean so it all shines.
Costs nothing and can do no harm only good
![Wink :wink:](https://lotuselan.net/forums/images/smilies/icon_wink.gif)
- alan.barker
As a test take the battery out of the boot and using two heavy guage jumper leads connect the positive direct to the solenoid and the negative direct to a hard point on the engine block. If the car then starts normally under these conditions you've isolated your problem to be excessive resistance across the main battery wiring going from the boot to the engine bay.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks all for the replies, I now have a few more things to check, although it's looking like a starter failure as no one has mentioned the possibility of the solenoid being the culprit. I don't quite understand why the voltage across the solenoid contacts drops to zero upon cranking but electrics were never my strong suit.
At least I am now fairly quick at removing the starter, having done it a number of times over the past few years!
Happy new year to all, here's to a better one coming
Robbie
Robbie
The voltage drop across the solenoid being zero is correct behavior, indicates both sides are at the same voltage (e.g 12.3 - 12.3 = 0). Which is what you'd expect for a good solenoid.
- mbell
Ah! of course, that makes sense. Thanks Mark
Robbie
Robbie
Sorted, dead starter was the culprit, now replaced and back on the road.
Thanks for all the replies
Robbie
Robbie
will you rebuild your dead one?
Love your Mother
Earth
Love your Mother
Earth
The dead one is with the remanufacturers for assessment. They are a bit concerned it has failed in such a short space of time. Depending on the outcome they have offered to fix it and return it for me to have as a spare should I need one
Robbie
Robbie
