Create a flick wipe?
Toad's headlamp dip switch has a built in flasher function. This was disconnected as some point, presumably 'cos its a bit useless.
Could I use this to create a flick wipe? Brown wire from the switch (permanent live) to the existing wiper switch?
Contacts 4/5 are the return to park circuit? Therefore 2 or 3 would be the one to use?
See any problems with this?
- vincereynard
A battery to 3 ( fast ) on the wipermotor will set it off ( 4 on the switch , I think ) , mine was red/yellow or Light green.
Ah you noticed!! Strobes - yes well I do have a problem growing up and years ago I got so fed up with motor homes blocking the roads in the Alps and other mountain roads I thought that I would try a few mods to aid attention getting! I already have a set of old Italian police horns, two note alternating, and also fitted two triple alternating white strobes behind the grill. All illegal I know but it does work!! Strobes from Whelan in the USA.
- TBG
That reminds me , I had two spots fitted behind the grill , with two flick switches on the centre console , on in the up position and on ( spring loaded ) in the down position , below the two white lamps in the picky.
Deft flicking of the first and index finger shifted most vehicles in front...
