+2 dashboard fittings and under dash trim
Hi guys
I'm looking for photos of elan +2 dashboards mounting brakets in place in order to understand how it need to be
I only have the dashbord wood panel and fiberglass in car and I don't know exactly what I need !
mounting bracket sales by sjsportscars :
and same question about under dash trimming, how is it fitted, is there some brackets too ?
thanks
aurelien
thanks
aurelien
- mini90
The Lotus parts list For the Plus 2 shows the way all the subassemblies fit together in exploded diagrams - it’s invaluable if you are rebuilding a Lotus
Visit me on matthewvale.com
Matt Elan - Fourth Gear
Parts manual is on rdent site:
http://rdent.com/manuals/plus2/
I think you need:
http://rdent.com/manuals/plus2/body/bbs.htm
The metal bracket fits on the outer edge. The trim pieces are secured to the under edge of the dash with screws.
I think you need:
- mbell
Hi Aurelien,
What year is your +2? The dash trims are different between the early and later s models.
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
http://rdent.com/manuals/plus2/body/bb.html Part no #5, a small metal plate with 2 studs welded to it. There are two, one at each edge of the dash panel. If you have the original panel you should find x4 small screw holes where each plate fits.
The part shown in your first photo attaches to the plate and the courtesy switch (#22) holds the other end to the body.
#23. This appears to be a bracket for the bonnet release, my car has a different version that is screwed to the edge of the dash panel.
I am not near my car to take a photo.
I also note that your gear stick does not appear to have the anti sizzle fitting that puts the stick further away from the dash panel.
Hope this helps
Adrian
edited to add part numbers for clarity and additional content (#23).
Hope this helps
Adrian
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
I found this on my phone. Each small rectangular bracket is held on by x4 very small screws. I got the screws from a railway modelling shop.
- wotsisname
