Radio Choice S4 Elan
I am approaching the point where I need to decide what to put in the radio aperture. I have a Phillips Turn o Lock, but it works on long and medium wave. There is a hole in the body for an aerial.
I don’t understand radio, stereo or in car entertainment, I only listen to BBC radio 4. I would like to keep the dash looking period correct, but don’t want to spend a large amount on something I won’t use or appreciate. Can anyone advise, or make suggestions? Is there a system that can be installed in the boot but controlled remotely?
Richard Hawkins
Richard Hawkins
- RichardHawkins
I understand BBC 4 still emits in LW, so an aerial would let you hear it on Philips the Turnolock 314 (which is the model I suppose you have, I had one in my S4 and gave up on it when I installed a TTR fast road exhaust)
or these radios are quite easy to modify to get a line in signal, that could then be supplied by a phone output, a MP3, or blue tooth operated device... (some fettling required - e.g. 2 wires to solder on the volume potentiometer, or a bit more elaborate, tons of sites about the subject)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:I understand BBC 4 still emits in LW, so an aerial would let you hear it on Philips the Turnolock 314 (which is the model I suppose you have, I had one in my S4 and gave up on it when I installed a TTR fast road exhaust)
Radio 4 is still transmitted on Long Wave at 198kHz from Droitwich, although its on borrowed time - the BBC have a limited supply of transmitter output valves (tubes) and when they are gone, they are gone (the site is actually now owned by Arquiva, BBC spun out its transmitter sites in the 90s).
I spent a few weeks at Droitwich in the early 80s as part of a BBC engineer training course when it was still in its art deco splendour. For those interested:
https://www.bbceng.info/Operations/transmitter_ops/Reminiscences/Droitwich/droitwich_calling.htm
Reception in a car on Long Wave is likely to be pretty poor unless you have gone to reasonable lengths to suppress interference from the ignition system. The Elan is particularly prone to this as the glass fibre doesn't provide any shielding, and provides a poor ground plane for the aerial.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I went down this route and got my Phillips Turnolock modified to accept iPhone output and use it to stream the radio. Works fine, of course with no interference. The LW facility is retained so keeping the radio’s value, although LW is not useable unless you have extensive engine suppression.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
englishmaninwales wrote:nmauduit wrote:I understand BBC 4 still emits in LW, so an aerial would let you hear it on Philips the Turnolock 314 (which is the model I suppose you have, I had one in my S4 and gave up on it when I installed a TTR fast road exhaust)
Who did you use, out of interest ?
'72 Sprint
'72 Sprint
- richardcox_lotus
Walmley Classics. rogerbeasley4(at) msn.com or zero seven970424616
Edited at add: I paid £60 for the conversion.
Last edited by englishmaninwales on Wed Aug 05, 2020 12:44 pm, edited 1 time in total.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Slightly left handed solution that I use is my telephone - that I use for navigation using the fantastic Waze - connected to a bluetooth mini speaker on top of the dashboard so that I can more clearly hear the young ladies navigation instructions and when we stop in the ferry queue or are just pootling along one can play music, news, you tube videos et all. Works for us.........
- TBG
Thanks everyone, but I should have explained my level of incompetence better. I don’t have a smart phone, I don’t know what an MP3 player is, and there is so much stuff on the net using terms I don’t understand to the extent that it may as well be a foreign language.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Richard,
Most of the basic conversions involve intercepting the radio's innards between the bit in the radio that picks up the radio signal and turns it into a low level audio signal, and the bit that amplifies this low level audio signal enough to drive the speakers.
Injecting a low level audio signal from a different source (usually the headphone output from a phone) at this point allows the radio's existing amplifier to drive the speakers, and has the advantage that the radio's front panel volume control should still work.
A lead is brought out of the back of the radio either into the glovebox or dangling under the dash to plug into the phone or other music source's headphone socket.
32 Standard 12
32 Standard 12
- Andy8421
Hi Richard,
I know you said you didn’t want spend too much, but this site may be of interest.
https://www.tadpoleradios.co.uk/Default.aspx
Colin.
Colin.
RichardHawkins wrote:I am approaching the point where I need to decide what to put in the radio aperture. I have a Phillips Turn o Lock, but it works on long and medium wave. There is a hole in the body for an aerial.
Richard Hawkins
'68 S4 DHC
- fatboyoz
Hi Steve,
Not sure about the German radios, but most of the Radiomobile and Motorola units are the correct size.
Colin.
uote="elanfan1"]Wow! Those prices are eye watering. I doubt any of the ones listed would fit in an Elan dash.[/quote]
Colin.
'68 S4 DHC
- fatboyoz
elanfan1 wrote:Wow! Those prices are eye watering. I doubt any of the ones listed would fit in an Elan dash.
If price is a concern, but you are prepared to sacrifice some originality, then this:
https://www.ebay.co.uk/itm/Classic-Car-Radio-Bluetooth-Stereo-Player-MP3-USB-SD-AUX-FM-In-dash-Head-Unit-UK/373119166940?_trkparms=ispr%3D1&hash=item56dfa2a9dc:g:cswAAOSwTAhesSRh&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickk8ihYa55VeJusc0Ydu6jng%252FpBqyTKs9oWlQI0z8oG3dTzjy1E80tF%252F4skwwUIcj%252BclE3AudSCdCoWrLCMK7sB76NsktO7bVgOoWpXpW7Q2XZA4NEwrnS3qlNT4mkC8a1WbIi4AK4pwYPDYY36au1fAsErvj2jcpL05PARWMkRjjq4sYj0RSjytS4LdLV%252B4q7xBDxxomluGFBbzIIg7SvXVqCa1YoiooLrV67c%252BSv%252FWtoLbdxp2pp8IyT%252FiW%252B9jXpSpdJa3bFE%252Bf5260cSt%252FwuclOoBqGqSccInKK4IjO%252FUnuphhkgtzCpS8WI7Bquc%252Bjy46tKyZCRKjss1W2KWxxoiUxVUQ60Yehkg3mrIfrpXj3SNfdNiuiY1SRe8XKa4VZ7fgt50cNI8NXKXmbsnNP0JZyQzGpC5IHP56xMlFICgzUnVK8QTKxU4QWAasr0wFQaa575Qk%252FMGncT745uCFDMmL8fd9jbpWkXzFh4oUQB5ORIH6jCyj%252BzF7lFVnDgwTwDZ1gC9mjB7R0yyJEUhws0TsUJeJN6E0ik7kqMj2%252FXzzZ80cOMHJvG0IF7pdfO%252FvTXLH2o4TUe%252BYA%252BL4NkOguhxyfQGI3du21p0dmtkZKYgfyme%252FFqDlw%252Ft2qfLYJVjF%252Fwnh1E6eopgsncDdgl1fGVaVzdHGYs2btTruy%252FQl3ui6PlX5SJnspgSIMhBcM4YPbu2A6zGWrCovO3uUqOC7xp1bnivNBRFsgQ6ejO9M8QvjmXoocueuVbYLGQnWMIDgrzAhFitVFI6539QjbzFi1Bgw%253D%253D%7Ccksum%3A3731191669403cf7625ec221461f9b79d65180c16f40%7Campid%3APL_CLK%7Cclp%3A2334524
Is remarkable value. Unlike many of the old radio conversions, it really does support MP3 and syncing a Bluetooth phone, and doesn't need an MP3 player to operate. Just put your 60s summertime playlist on an SD card, and off you go.
32 Standard 12
32 Standard 12
- Andy8421
Users browsing this forum: Lotus54 and 13 guests
