Fuse Size
The originals are Lucas 35A/17A fuses. I've interpreted that to mean that they are "slow blow" fuses that take 17A continuous and will take a quick peak of up to 35A.
I'd like to see an EE chime in on this one.
<span style='font-size:9pt;line-height:100%'>Best regards,<br>_<span style='font-size:13pt;line-height:100%'><span style='font-family:Times'><i><b>Bob</b></i></span></span><br>______________________<br>[email protected]</span>
LotuSport - Third Gear
35 Amp fuses are fine, at that current the wires will burn up way before the fuse ever even considers going, excepting a 12 gauge wire... mine did! I then replaced my fuse block with a six fuse ATO style fuse block from a marine supply house. Each wire got it's own fuse. I then swagged at the fuses to use based on what was the load device was. Simple, cheap, quick. And NONE of the fuses needed to be 35 Amps!
Mike Geiger
66 Elan S3 COupe'
Mike Geiger
66 Elan S3 COupe'
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
