Elan Federal S4 hazard switch
My '69 LHD Federal Elan has a Hella brand hazard switch that's mounted in a hole in the valance panel under the dash. So, it's located near my right knee when driving.
Is this a standard hazard switch from the factory? I'm wondering because it's not a Lucas part and it's not in a convenient location for emergency use. It's also not shown in the parts book.
Also, does anyone know if a new wiring harness will work with this switch, or if wiring would need to be modified to fit. I might rewire the car and wonder about this.
Thanks for any replies.
Bob
1969 S4
1969 S4
- lotocone
Your hazard switch is not standard. The Federal S4 hazard switch is a small slide switch attached to a bracket under the dash that also holds the bonnet pull as well as a push button that tests the brake fail light.
You will probably have to adapt any standard harness that you buy, to accommodate the hazard switch but it is not that difficult.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
my '68 Fed s4se has the slider switch underneath the dash above the parking brake, but I've also seen some cars with a 2 positions toggle switch similar to the other square ones integrated to the dash panel as a third switch in the middle of the bottom row.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Thank you for your replies. I guess Lotus made a change to the switch along the way. My car was built in Dec. 1969 and it doesn't have the slider switch.
Rob, thanks for the info on the Sprint.
Here is a picture of the hole in the panel where my push button Hella switch is located.
Bob
1969 S4
1969 S4
- lotocone
One Owner 69 Elan,
Thanks for the comment about the bracket beneath the dash. My car is a 1968 S4, when I dismantled the car, this bracket was dangling beneath the dash and bent to a funny shape. Now I know what is for.
Richard Hawkins
Richard Hawkins
- RichardHawkins
