Elan plus 2 fog lamps
I’m looking for a part for the fog lights and it’s dificult to find so I should buy a new pair of fog lamps. What is the diference between spot and fog lights? I don’t know which type I have so I put a picture.
- Dieschelan
Hi. The light in your photo has a lens with a beam pattern. This indicates it is a fog light. Spot lights usually are a plain lens for a direct "spot" of light. Fog lights are mounted below the bumper to light below the fog. Spot lights are above the bumper maybe as high as the main lights to light into the distance.
Good luck finding your part.
- Lyn7
Pretty sure my car has one spot and one fog light. That was fairly standard in the '60s.
- mikealdren
Go into ebay and put in 'H3 lamp clip' and any number of hits will pop up.
The only problem is that you cannot buy a single clip for an H3 bulb - you have to buy a pack of clips that suit all the H series bulbs, and throw the rest away Prices for the packs range from 6€ - 8€, but cheaper than buying a whole new lamp...
https://www.ebay.es/itm/6Pcs-Bulb-Retai ... SwzCFehr71
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
