Strange boxes
I would like to know what the two electrical boxes are. The one box is an aluminum ribbed enclosure with (6) wires going to and from various ignition components. The other box marked “transpo” has (4) wires going to who knows where. None of the color coded wires aligns with the factory schematic.
Is anyone familiar with these two boxes?
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Possibly an after market external voltage regulator made by Transpo Electronics, now owned by a larger company. https://alternatorparts.com/transpo-com ... ation.html
It's a slow day waiting for epoxy to set up.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
When you add the filler powder to West Systems epoxy it seems to take forever compared to the same epoxy without it. I wish I could say it was a Lotus project, but it wasn't.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
HCA wrote:It is an electronic ignition module - quite an old one, I’d say.
Yep, a 'capacitive discharge' electronic ignition module. Capacitors don't age well, and they don't like heat. If reliability of your car is on your list of requirements, I would show the module the door.
I would second the analysis of the Transpo box, its probably a regulator. Do you have an after market alternator fitted? If so, this could be its external regulator.
Frankly, given that many an Elan has been lost to an electrical fire, I would be tempted to rip the whole lot out, tidy everything up with new connectors and fittings, and as a last resort consider a new loom.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
It is my plan to replace everything including the wiring harness. I would like to understand how this all works because I want to enjoy the car for a while before I rip the electrics out. Since the car uses a standard points and coil ignition system, what does the CD unit add to mix?
67 Elan +2
67 Elan +2
- seniorchristo
A capacitive discharge ignition uses a inverter to step up to an high voltage probably around 400V which charges the 600V capacitor you can see the points are the trigger to discharge the voltsge into the coil giving a very high spark plug voltage work very well as long as your insulation is good and the coil clean of oil and dirt
Ian
Ian
- elansprint
Thanks for explaining Ian.
67 Elan +2
67 Elan +2
- seniorchristo
Chris, talking about reliability..... I had found the same setup on a Europa I rescued after sitting decades. I hooked up a battery and the motor started right up! So there must be something good about it for a previous owner to install.
TED
- tedtaylor
