Headlamp pull switch removal
Removed all the switches lights etc from the dash today, the cigar lighter was a pain but came out ok but the ceramic heat shield was broken so may need to source another, but one unit is proving to be a right B@$*^%d to remove... the head lamp vacuum pull. I may have twisted the push bar but if I can get it out I think I can fix it. The tabs at the back do not want to budge. Any ideas?? Please.
- djb222
Spring-loaded "button" in the knob...
Edit Looks like you've removed the knob?
There is a small hole in the side of the knob. Slide small dia rod down inside the hole to the bottom and push. This will release the spring loaded button at the bottom.
- alan.barker
Thanks.... Success, Black Knob removed and yes I'd twisted the shaft so it wouldn't slide back and forth. Managed to dismantle it and straighten the shaft and will reassemble tomorrow. These head lamp pull switches are so hard to find, found a really rusty one for £80 and one of the usual suspects is selling just the black Knob for £40 +vat
- djb222
You can buy the black plastic knob from "Rimmer Bros UK" it's Triumph Herald and much cheaper
- alan.barker
elated wrote:The Triumph knob is identical but its icon differs
Gordon
I'm sure if you didn't tell someone they wouldn't notice. Unless they are wearing an Anorak
Got one on my sprint no problem
- alan.barker
