connection fan !
I dont recall ever seeing a fan wiring diagram in the Two Seater Lotus Manual (although it may be there )
I believe the plus two wiring diagram contains a fan circuit allthough I dont know if its through a relay.
Anyway I hope this thread and its links may help you.
viewtopic.php?t=38732&p=267809
I?m pretty sure the basic fan circuit is on the S4 wiring diagram but as I?m away from home at the moment I can?t check it. If you want a manual override that?ll be a diy addition but it?s not a difficult bit of wiring.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
I just checked since the workshop manual diagram doesn't have it.
The drown with blue strip accessory power goes into the thermostatic switch and comes out on a Green with black stripe wire. The green with black strip goes into the fan motor and comes out to a black ground wire.
If you want to add a manual switch just put it in parallel with the thermostatic one. If you want a light tee it off the green with black wire.
Rob
Rob
- Rob_LaMoreaux
I also could not find anything for the S4 & Sprint, these were the wiring diagrams that I found for the +2 & Europa:
Note in all cases full fan current goes through the temp switch which can (& does) burn it out.
This is the wiring that I implemented:
I think this meets all the OP's requirements.
The additional relay is attached to the narrow radiator side plate.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
geni wrote:merci de votre partage ,mais je d?sire connaitre en explicite les fonctions de chaque relais pour la Sprint
thank you for sharing, but I would like to know specifically the functions of each relay for the Sprint
Are you totally changing the subject & asking what do the relays under the hood in a Sprint do? If so, they are headlight relays, see attached.
Phil Harrison
Users browsing this forum: mark030358, Sadbrewer, snowyelan and 17 guests
