Help with dashlight and switch.
It's a ?68 plus 2
Thank you
- Bozzie
ncm wrote:Has the car been fitted with a heated rear window? Could be the switch for that with a tell tale light in the dash.
Brian.
Later cars which had the heated rear screen had a warning light in blue/purple so Brian may be on to something there.
Robbie
Yes, there is indeed a heated rear screen so maybe that's it! I will check tnus out later when I'm with the car and let you know Am I right in saying the right side located indicater should be the only control on the steering column shroud?
Thank you
Thank you
- Bozzie
With one stalk on the right, this operates the dip switch, to/from the driver, the indicators, up/down and the horn by pressing the button on the end of the stalk. Some have added an electric screen washer and you may have a button for this somewhere. No light like that on my car on the original dash but my new replacement dash does have a hole there ready for something.
- Bigbaldybloke
