Ignition Advance
• Page 4 of 4 • 1, 2, 3, 4
nmauduit wrote:Foxie wrote:Davidb wrote:Yes, you download an app to your phone and it shows a 'dashboard' with rev counter, ignition setting, temperature and other things. You can adjust the timing as the car is moving--just like drivers could in the 1920s!
What is this app ?
How are the settings read ?
Where is it available, and where can I learn more ?
The app/software would be available from the 123 ignition website https://123ignition.com/support/ (no affiliation)
Thanks for that. I've had a good look at the website and videos.
It seems that the advance curves and timing are completely electronically programmed, visible, and variable, thus eliminating mechanical errors and points problems.
And a physical distributor is still retained, as some Historic classes will not allow coil packs.
Looks good to me, I might give it a try !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
