Bonnet Light Bulb
Can anyone tell me where I can get a bulb for the bonnet courtesy light?
The 2 contacts are sprung and the circuit is through both contacts, like a domestic UK light bulb,
so I cannot use a normal auto bulb.
Not that I can see the bulb lasting long under the bonnet over the exhaust!
- vincereynard
That's a B22 fitting I believe - here you go LED so should last forever and is 3w so will probably give equivalent light to a 30w conventional bulb - on that basis I'm sure it's worth the money:
https://www.amazon.co.uk/Mark8shop-Bulb ... v+b22+bulb
elanfan1 - Coveted Fifth Gear
Steve,
Thanks for that.
I suspect that the "22" bit is the diameter of the fitting - Bayonet 22mm.
This is standard car bulb so more like 15 mm.
http://www.autobulbsdirect.co.uk/LED-Bayonet-Bulbs ?
Except it would have to be a double contact like a domestic bulb.
Thanks for that.
- vincereynard
I was going to suggest a stop/ tail bulb. But I think they have offset pins
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Are these the ones?
http://www.ebay.co.uk/itm/10-x-Autolamp ... Sw6YtZQ4lr
Higher wattage ones here
http://www.ebay.co.uk/itm/2-x-Double-Co ... NlwDgF1hLw
Kindest regards
Alan Thomas
Alan Thomas
Thanks Alan.
I looked without finding.
So it looks like 209 is the 5 watt bulb, and 335 is the 21 watt.
http://www.ebay.co.uk/itm/2x-335-12v-21 ... 100623.m-1
Take your choice, although I suspect a 5 watt would be a bit dim.
- vincereynard
elanfan1 wrote:Go for LED versions much much brighter and last.
The link you gave only seemed to show 22 mm version and 240v.
I could not find a 12v that would fit.
- vincereynard
Spyder fan wrote:Just search for BA15D LED
Thanks again Alan.
- vincereynard
Users browsing this forum: GaryE and 34 guests
