voltage regulator
Hello folks
I dont understand the voltage regulator connection in the circuit diagram.
Attached is a photograph, the red circled connection confuses me, what is this? I always thought that the regulator provided stability for instruments like the fuel gauge so that readings were consistent? Non of the other instruments require this do they? The only other I can think of which might is the tacho. Could the confusing connection be just this?
Bob
Bob
bloodknock - Fourth Gear
Sorry folks
what an idiot I am, I can now see that the red circled connection is raw 12v supply to the tacho, its only the fuel gauge that has a regulated supply. same coloured cable though!!
Bob
Bob
I thought the oil pressure gauge had a stabilised 10V supply also..,,or was it the fuel gauge ?...
Friday night again and a nice bottle of red...
i'm looking for stabilised 45 PSI at operating temp 3k rpm! Dont think the voltage regulator will help.
Bob
What you need is a high capacity ( not high pressure ) oil pump,with the correct pressure release spring fitted..
