Elan Sprint short problem, and fuse box
Hello,
I currently have a short circuit problem on my Sprint.
I is equiped with this kind of fuse box, but I can't find a document stating what circuit is protected by each fuse.
The fuse pops when the key is turned to the second position (when the electric fuel pump is activated. Sorry I don't know the name of this in english).
It would be easier if I knew what circuit is protected by the 20A fuse that is popping.
Is this fuse box original on some Elans or is it aftermarket? If original, does someone have the appropriate wiring diagram?
Thank you!
Thank you!
Caterham 1600K SS
Paris, France
Paris, France
- zimzum
Hi R?mi,
looks like a modification to me (most likely installed when swapping harness), but if you're lucky the color code of the stock harness has been respected on the tail end of the wire : you may spot check some against the standard colors, then narrow down your search... good luck !
http://www.barnblinker.com/2016/02/14/l ... g-loom-s2/
http://www.mgexp.com/article/lucas-colours.html
http://www.barnblinker.com/2016/02/24/l ... g-diagram/
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Hi Remi
Take out the fuse that fails and then see what function on the car is not working.
not sure how the sprint is wired. But on the second position on my +2S
circuits that power up are ignition coil circuit , most gauges, fog lamps, rear screen heater
( the sprint won't have this) indicators, stop, and reverse light. so if any of these don't work that
would give a clue
If you have an electric fuel pump this is not standard as most Elans originally had mechanical fuel pumps
that would be expected top be energised with the rest of the ignition system.
Hope this helps
best of luck
Bob
would give a clue
Hope this helps
best of luck
Bob
- bob_rich
Thanks.
I have checked the branch of the loom connected to the fuse, and it is feeding the electric fuel pump, indicators, heater switch, washer switch, wiper motor, washer switch, plus most of the gauges.
The short was because of a wire that have been cut (not used anymore) but not protected. It was in contact with the oil pressure hose going to the pressure gauge...
Now fixed and protected with a sheath.
Thanks!
Thanks!
Caterham 1600K SS
Paris, France
Paris, France
- zimzum
