Battery replacement options
Fellow enthusiasts,
The standard battery is designated a 038 / 015 but what are the thoughts on putting something stronger ,especially as regards CCA in as long as it fits the boot space comfortably (135 cm width.) eg .
https://www.tayna.co.uk/DA45L-Duracell- ... P9542.html
- PhilatHooton
Phil
I have recently fitted a 075 Battery to my +2 , (Varta D21, 61A, CCA600, 242x175x175mm) as the new battery was a few mm wider than the well of the battery containment I filled the well with a wooden board to bring the base level to that of the boot floor adjacent. Removed the boot wall retaining tab and fitted it a little higher to suit.
The board I installed had an oval cut out in it to allow the use of the original clamp suitably flattened in a vice.
This battery is excellent and turns the engine over great, I am well pleased as the original 45A batteries were useless
You do not say what car you have is the elan the same as the +2 arrangement?
- Attachments
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
John, thanks for your prompt and informative reply..
I have a +2s130. I like what you've done and with the dimensions of the battery you used with a low height of 175 mm i presume the boot base boards clear the battery top without modification. i must confess that i've had the car decades but never had the battery bolted down as it sits on some felt and is such a snug fit barely moves.
.I may have to rig up a clamp though if i follow your route.
No problems keeping the battery charged with the standard alternator ?
Phil
Phil
- PhilatHooton
Paul,
Thanks for you reply but it's somewhat above my budget though as you say a serious bit of kit.
Where does that other earth lead that runs up beside the live go to ?
Phil
Phil
- PhilatHooton
Vince
Yes the boot floor fits ok and has in fact more space than the previous battery.
The reason I wanted to fit the 075 battery is that they are plentiful and at a reasonable price. All batteries deteriorate in time especially in little used classics.
As regards the alternator mine is a 45A Lucas A115 unit and charges the battery fine.
PM me if you require any more info
+2s130 1971
+2s130 1971
I have fiited a Bosch S5 660 CCA battery in my plus 2.
Before anyone asks, no, you are right it is too big to go in. I cut a very small 2" wide hole in the boot floor and then reglassed over to make room for the battery.
Shedloads of power, especially when the car has been sat a while, infinetly better than the 038 Mini battery that was the original.
I paid around ?60 at the time as the battery was on offer, I think they are around the ?80 mark now?
Jeff 72 +2
Jeff 72 +2
jeff jackson - Fourth Gear
pauljones wrote:It goes direct to engine bay to form an earthed curcuit,
While there is nothing wrong with running an additional lead in parallel to the metal frame, it won't make much difference. Steel has a higher resistance than copper, but the cross sectional area of the frame is much greater than the cross sectional area of the copper cable.
ACBC would be rolling in his grave at the weight and cost of an additional cable when the frame can (in time honoured Lotus tradition) can be asked to do two jobs - keep the wheels apart, and be an earth return for the electrical system.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I apreciate your coments Andy. Its working better than ever now its fitted. Also im saving weight by fitting the Battery, so im sure its all in ballance.
More a peice of mind item that's doing a great job
- pauljones
Hawksfield wrote:Phil
John,
I have followed your option and fitted an identical battery.It was the most powerful one for its size,was great value from Tanya Batteries and comes with a 5 year warranty. I made a wooden base to raise the battery to sit flat in its position with a lip to help hold it in place. It fits a treat. Did not have to alter the height of the boot base boards or back panel. Should have done this years ago. Car starts instantly. Thanks again for your info.
Phil
- PhilatHooton
FWIW, in the S3 Elan that I race(d), I have a Varley red top battery in the bottom of the passenger's footwell. The battery is tiny, and makes very little difference to the space available for feet.
It has a number of advantages. It saves weight in of itself, the cable to the starter is very much shorter - saving weight and having lower resistance, and it reduces the polar moment of inertia of the car.
I have seen it suggested that having the battery in its standard position improves weight distribution. Putting something heavy in the corner of the car is never a great idea from a handling perspective, ideally it should be in the middle of the car and as low as possible. The passenger's footwell isn't a bad compromise.
Probably not a great idea from a road going perspective, but when I finally get around to restoring my Sprint I guess battery technology will have moved even further. I have seen that LiFePo4 batteries now being used - which are even smaller and lighter than the racing battery I have.
32 Standard 12
32 Standard 12
- Andy8421
Andy8421 wrote: The passenger's footwell isn't a bad compromise.
Hi Andy
My LiFePo4 batterie works perfect.
See here:http://www.lotuselan.net/forums/lotuselan-plus2-f51/lithium-batteries-t38812.html
Urs
ElanDNA - Second Gear
Found to my horror yesterday, that I had let my battery run down over the winter to just 1.2 volts, a tenth of what it should be. And it was a relatively new battery!
Put it on charge overnight and was pleased to find my Elan started relatively easily today, so it seems it was not damaged.
You were lucky to be able to recover the battery. I've found that the newer Calcium batteries do not like being allowed to go flat (or even below 10 volts) and may not recover with a normal charger. The battery makers thinking seems to be that CCA or maximum starting current is the real deal now rather than the Amp hour capacity as modern batteries are only needed to start the car. When running, the alternator takes care of all the electrical loads and still has enough spare even at low speeds to quickly recharge the battery. Hence the battery should always be fully charged. This is not the case with dynamo cars where the electrical load can significantly exceed the dynamo output especially when driving with lights, heater and wipers on in slow traffic. The result is that after a run the battery may well have a lower charge level than when you started out. A permanent trickle charger once back in the garage is essential if not using the car regularly. By the way look at the T&C's on battery warranties - they are often very limited and almost worthless in practice. Halfords batteries used to be made by Yuasa, not sure who makes them now. I've just gone for an Exide Excell range battery for my +2S130 Only time will tell if it is any better than the old Halfords unit or cheapo Lion brand battery in another classic.
- RedBarnMan
