Voltage Stabiliser Replacement/horn Problem
Please Help.
I am trying to replace my voltage stabiliser due to problems with temp guage readings.
I swapped out the old one with the same wires except that I replaced the old earth wire that was giving a weak current with a better new one.
For some bizarre reason the horn is now permanently on when I turn the ignition key. I can find no obvious reason for this in the manual.
If anyone can help I will be eternally grateful.
- williamselby
I can't think of any obvious reason why improving the ground on the voltage stabilizer should affect the horn. Make sure the horn circuit is not running through the voltage stabilizer - only the instruments should be connected here.
I had a similar problem with my car, and found the steering wheel had moved forward enough for the wheel to contact the horn connections, making a ground and activating the horns. Readjusting the telescoping section of the column worked for me, but putting a plastic shield under the wheel might be a better solution.
BillGavin - Second Gear
Had the same proble, when rummaging under the dash I had leant on the steering wheel ..climbing in and out. I had pushed hte alloy center boss so that the little springs made contact withthe column, completing the circuit , with the same result...
but I just realised that the horn should always be 'on' if it is on when the ignition is turned only, it must be the wiring, cos a horn needs to work without the keys in the ignition !
LaikaTheDog - Third Gear
check you've not operated the switch in the glovebox accidently
