Coil relocation
Elan S3. I know that some of you have moved the ignition coil from the standard and rather vulnerable location under the carburettors to a safer place - any recommendations? Not long ago I had a major fuel leak from the front carb when the engine was running, so I was very lucky.....
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Hi Malcom, the coil on my S4 has been moved using the bracket that is available from CliveyBoy - you can see the new position in the attached picture.
"What kind of a man are you? Don't you even like dolphins!?" - Zorba the Greek
69 Elan S4/SE DHC
66 Ford Mustang Conv. (289ci)
71 Cadillac Eldorado Conv. (8.2L)
65 Buick Wildcat Conv. (425ci)
And a pickup truck full of Miatas....
69 Elan S4/SE DHC
- SF69Elan
Mine is under the glove box in the foot well.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I'm considering doing the same in my S3 Malcolm. Think I'm going to go for the Clivey Boy bracket, but would be interested to know how you get on.
1967 S3 SE DHC
1970 +2S (RIP - went out in a blaze of glory in 2001)
Stevie-Heathie - Third Gear
I didn't have metal working facilities but did have fibreglass materials! I relocated my coil to the upper radiator bracket with a homemade FRP bracket.
'67 S3 SE FHC
'67 S3 SE FHC
englishmaninwales wrote:Elan S3. I know that some of you have moved the ignition coil from the standard and rather vulnerable location under the carburettors to a safer place - any recommendations? Not long ago I had a major fuel leak from the front carb when the engine was running, so I was very lucky.....
Malcolm
While I don't think its a bad idea to move the coil from its original position under the carbs, a properly connected coil shouldn't in of itself be a fire risk. The distributor however is an accident waiting to happen if covered in fuel. Tough to relocate though.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
SF69Elan wrote:Hi Malcom, the coil on my S4 has been moved using the bracket that is available from CliveyBoy - you can see the new position in the attached picture.
That's where I put mine; it's a bit cooler than the standard location; I just used a generic coil bracket and bent the two "legs" slightly.
Pete.
http://www.petetaylor.org.uk
Pete.
Thanks for the ideas. Keep them coming!
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Not directly relevant for the OP but on the plus two I've seen them relocated higher up the inside wing and also to the top of the peddle box on rhd cars. Both locations improve access and move away from the carbs.
- mbell
OK I went for a location, as suggested, just behind the radiator, using the standard coil fixing to the chassis/body fixing in the front upright box section.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
