Nippon Denso Alternator Mounting Bracket
I have a bracket for a Lucas alternator which I plan to use one day. I can send you a photo and dimensions if you like.
Carl
Carl
pereirac - Fourth Gear
i used the standard bracket ,cut off the rear lug on the bracket and moved it forward to suit then welded it back on ,a bit of zinc plate later it looks good ,ajusting bracket on the top is off a ford escort with a roller gear for ajustment with lock nut ( no need for a crow bar behind the alternater to hold it in place while you tighten it ) :blink:
"everyone wants a piece of me and it hurts "<br>when my right leg starts shaking thats when i know i am having fun !
- steve
I had a bracket made up using an original BDA mounting as a template.
The new bracket is bushed along it's length and a plastic strap is used to mount onto the timing cover.
The timing cover has an additional strap onto the back of the timing cover to disperse the mounting load.
I dont ever envisage thrashing the engine that hard but the engineer who built the engine and fabricated the mounts assured me that once that Elise appeared in the rear view mirror.............
I'll post some photographs of the conversion in the next couple of days including some pics of his Escort BDA.
Happy motoring!
Happy motoring!
- Psion
Users browsing this forum: No registered users and 46 guests
