refurbing window mechanism - part found missing
Looking at that link above: the diagram from the Parts List in the Wiki, shows that the Plus 2 window mechanisms are drastically different than those in the two-seater Elan.
But I don't see a spring..
elanfan1 - Coveted Fifth Gear
All manual window winder mechanisms use a heavy spring like that, but I've never seen the spring sold separately. You could buy a used complete MGB or Midget window mechanism from ebay (or somewhere similar) and the spring might be the same, but I don't know if that is true.
TroonSprint - Fourth Gear
Hi Rich
sorry for the delay. I think the spring is an integral part of the assembly. the whole assembly looks to be from DELCO in the USA and I have recorded info on the window mechanisms in my rebuild diary and info is given below
The motor were marked as follows :-
Drivers Side 051-73 5045594 B Delco Products L
Passengers Side 142-73 5045593 Delco Products R. the blade was marked with the numbers for both left and right hand parts 7960626 R and 7060627 L.
Not sure that a spring is absolutely necessary. I think the idea is a stop the window moving or bouncing under shock. they are very strong spring and when I stripped down my motored I have to make up a temporary jig to allo me to wind the spring. I arranged my springs so that they gave assistance on lift - not sure is that is correct but both seem to work OK
Hope this helps
Best of luck
Bob
Hope this helps
Best of luck
Bob
- bob_rich
To confirm.
The spring helps hold force upwards against window glass weight
Love your Mother
Earth
Love your Mother
Earth
