2 speed windshield wiper vs 1 speed
my car "came" with a "generic" (cortina) wiper switch and a pushbutton washer pump pusher - i don?t drive in the wet BUT ev ery once in a while i do get wet and at the speed i have to drive i?m happy with a one speed wiper; is there ever a situation on slippery roads where u actually need 2nd gear wiper speed - be honest please (i?m not talking about racing conditions in the wet) ------------------------------ besides the point: didn?t you like the loti in canada this afternoon??? alpine sandy - that sounds pretty gay dont it? 36 / 4982
- el-saturn
If you end up using a one speed motor you can easily speed it up by putting a resistor in series with existing connections, thats all that Lucas did to the two sped model by using a difference resistance wire on the coil as secondary winding. I'm working out the correct value for a car I'm finishing as I've been unable to source correct DR3A.
I'm pretty convinced that it is also possible to make a single speed two speed by using a resistor however intros case it would not be in series with existing connections and will require an additional connection. To maintain negative switching I expect t have to use it in conjunction with diode.
If I go this route happy to share the wiring diagrams and photo.
Vaughan
Vaughan
- vstibbard
Hi Folks
On the Elan ( at least on the +2 ) the two speed wiper does not use a resistor but switches to separate windings on the motor one for low speed and one for high speed. A screen wipe motor is a fair bit more powerful that a heater fan or engine cooling fan and these are contollable to a degree by reducing speed by inserting a series resistor.
Adding a resistor to a single speed motor will reduce its speed but some tests will be needed to determine the value of the resistor and it may be quite sensitive to the loading ( i.e friction) variations that the blades on the screen make. may make the resultant speed a bit variable.
Hope this helps interested 2 C how U get on
regards
Bob
regards
Bob
- bob_rich
One day i may look into rigging up an Intermittent on the first speed, its not used usually as it often just gets flicked on and off to stop it screeching when its not raining hard enough to warrant the none stop wipers. (if that makes sense) may not be such a big deal in the US etc but in the UK we have all sorts of Rain
Grizzly - Coveted Fifth Gear
The S1/2 used a continuously variable resistor in series with the field winding as a speed control though it never made much difference. I have rarely used the higher speed in modern cars and like Grizzly I would prefer an intermittent capability instead.
Meg
This is copied from some information I received from Alan Turner who sells remanufactured units: (searching alanjohnturner on ebay should bear fruit) . Sadly I can't get some of the diagrams to copy.
I understand this article has been publish/dispersed so Iam confident I'm not infringing any copyright.;
Lucas DR3A Two-Speed Wiper-motors
The Lucas two-speed variant of the DR3A wiper-motor, as found on Triumph TR4A and other vehicles from the same era, seem to create problems when people try to wire them up.
Often this happens when someone tries to use one to upgrade from a single-speed variant. There are a number of things about these motors that are ?counter-intuitive? and this leads people to guess wrongly in the absence of proper wiring instructions.
There will be useful information in here about using the single-speed types too and for the earlier DR2 type, found in TR2/3s and elsewhere, because these use more or less the same electrical parts even though the gear-wheels are different.
Rather than just give a set of step-by-step instructions, I want to explain how these motors archieve two-speed running. Hopefully this will put people on the right course to fit these as an upgrade in various suitable vehicles.
The single-speed Lucas motors from this period run a bit slow by modern standards. I'll be explaining how to speed them up a bit, so that if used with ?intermittent-wipe?, performance is more like a modern unit.
There are two separate electrical circuits in these motors, the Field-winding and the Armature-winding, and the relationship between the current that goes through each of these determines the running speed.
The Field-winding is a large flat coil that is clamped to the outer case and its job is to magnetise the the outer case and the semi-circular ?pole-piece?.
The Armature-winding is a round cage of wires, with the rotating drive-shaft in the centre. Current goes into the Armature-winding through the carbon-brushes.
I've got one of these from an E-type, that has all the wires from the Field and Armature-windings, brought out separately though the case. There are actually six wires in all! More on this variant later.
But the TR4A motors join some wires together inside and only three come out through the case. The diagram below shows how this is done. It also shows how the ?self-parker? is wired in.
A standard single-speed DR3 motor does not bring the wires through the case, like a two-speed variant. It has two ?spade? terminals that take push-on connectors. These are marked 1 and 2 in the alloy-casting, on the end of the motor.
There is a separate spade-teminal, markerd E, which is for connecting the case of the motor, to the vehicle body. The motor will run perfectly even if you don't connect its case to the car-body. But it won't ?self-park?.
The self-parker is a rotating contact that touches the case of the motor but only during about 3/4 of the wiper sweep. There is a ?gap? where it makes no contact at all. If you connect the motor-case to the car-body, you can use this as a switch that keeps the motor running, until the contact reaches the gap that is and then it ?parks?.
Check-out the following features on the diagram:
1. The 12V supply from the battery is at the top
2. it's connected to spade terminal number 2 and feeds the Armature-winding, through one carbon-brush and it also feeds the outer-end of the Field-winding.
3. the inner-end of the Field-winding is connected to the other carbon-brush.
A connection from here comes out on spade-terminal number 1.
4. the wiper-switch is connected to spade-terminal number 1 and completes a contact to the car-body in order to start the motor.
5. the red wire that is so obvious on the round ?cap?, is connected to the car-body by the rotating contact, IF the motor-case is ?earthed? by a wire on the E terminal AND the wipers are NOT in the ?parking-position?.
There isn't room to get three spades out of the case, so the two-speed motors squeezed the wires through the joint in the case and dispensed with the spades.
Part of the problem with converting to a two-speed motor is that you have to change from ?spades? to ?bullets? and this creates confusion. Especially as you have three wires on the motor and three wires on the car.
It just looks as if they should join somehow. But they don't join directly and nothing is obvious, because you need four wires from the car for a two-speed motor.
I've seen really complicated ways to get these motors to work. All have been created to overcome a problem that does not exist. They result from not understanding that the self-parker is a switch that makes a connection to the car body. A switch in the ?earth-wire?.
This means that ALL the switching of the speeds has to be done with switches that make contact to car-body, switching in the ?earth-wires? is the trick.
The other side of this is that there will be a direct connection from the motor to the side of the battery that is NOT connected to the body. Because this connection isn't switched there SHOULD BE A FUSE somewhere. One contact on the motor is ?live? all the time. Or at least all the time that the ignition-switch is on.
Notice I have avoided using the word ?positive? and ?negative? because originally most of these were vehicles were wired with the positive-side of the battery connected to the car body, so called ?positive-earth?, but many may have been altered to the modern ?negative-earth? method. This change-over has no effect whatever on the way the wiper-motor should be wired.
The motors rotate the same way round no matter which side is connected to positive and which side to negative. This is because both the Field-winding and Armature-winding will get changed around and what is important is the relationship between the two circuits.
Note that the wipers will behave the same no matter which way the motor runs. But there is a ?thrust screw? for one end of the armature shaft. The motor runs in the direction in which the armature ?screws? itself towards the thrust-screw.
Now, you better choose carefully which motor contact you connect to the live side of the battery! Because if you choose the wrong one then the self-parker will make a contact from one side of the battery to the other. This WILL blow the fuse IF there is one! Otherwise the self-parker will burn out. The diagram above will make this clearer if you are puzzled.
Lucas chose to mark the ?live? motor contact, on the single-speed units, with a figure 2 in the alloy casting. This is rather unexpected, I feel, and encourages people to wire the ?power? to the wrong contact, marked with a figure 1. Yet another cause of confusion!
Now we have covered the basic switching and wiring for these motors and we come to the two-speed stuff.
If you have an electrical test-meter, that can measure low values of resistance, you can check out some of this for yourself.
The resistance of the Armature-winding is much lower than the field winding. I measure about 1 Ohm across the carbon-brushes. The field-winding of a single-speed motor, on its own, measures about 8.5 Ohms.
Both the Field and Armature-windings are connected to 12V so that Ohms law suggests that the current in the Field-wind will be 1.4A and 12A in the armature.
This is what happens at start-up OR if the wipers get jammed or are frozen to the screen. But the armature will BURN-OUT if the 12A continues for more than a few seconds.
Motors found in more ?upmarket saloons? often have a thermal-switch to protect the motor. Triumph motors usually don't, after all the target market was California and drivers were not expected to use the wipers if they were frozen up!
As the motor runs up, the interaction of the field and the rotation generates a voltage and this causes the Armature current to fall back to its steady-running value which is about 2A. It is this interaction that allows us to vary the running speed.
If we reduce the strength of the magnetic-field, created by the Field-winding, then the Armature needs to turn faster to generate the same voltage. This means that to run faster, we want a SMALLER current in the Field-winding.
This is again counter-intuitive and anyone poking around inside the motor and finding the resistance-wire, that Lucas fitted to reduce the field-current ,will probably assume that they need to wire the resistance in circuit when they want SLOW speed. This is not the case.
In fact Lucas put ten turns of Nickel-iron wire with a resistance of about 10 Ohms in the two-speed motors. This more or less halves the field current.
A simple view suggest that this will double the running speed. But it doesn't. You will see later that I have measured the speeds and this ?field-weakening? only generates about a 50% increase in speed.
This is because of the phenomenon known as ?magnetic saturation?. This means that there is a limit to the magnetic field you will get no matter how much current you use. Its a property of the Iron used to make the case and pole-piece.
These motors have been designed so that there is more than enough current to get the Iron saturated.
This helps to get consistent performance in spite of manufacturing tolerances.
So reducing the Field-current a little does not reduce the speed. You need to halve it to get much effect. Even then you only get a 50% increase.
For convenience they wound the resistance-wire over the Field-winding. But there are not enough turns, compared with the main winding which has hundreds of turns ,to get any magnetic effect from this. Its just the resistance that's important. They could just as well have used a power-type resistor, but this would have cost more.
I am now adding power-resistors, to get faster running from the single-speed motors. These resistors are better at handling the heat generated and don't burn-out as easily as the bit of wire that Lucas used. More about this later.
So now we know we need:
1. a supply of 12V that comes on all the time that the ?ignition? is on
2. a connection from the motor-case to the car body so that the self-parker will work
3. a three-position switch, making connections to the car-body
4. the switch must ensure that the field currrent is reduced, by the resistance-wire, in the FAST postion but not in the SLOW position.
Again there is a trap for the unwary here. Not just any three-position switch will do!
To see why you must study the diagram below.
1. The 12V supply, from the battery uses a GREEN wire and feeds the Armature-winding through one carbon-brush and it also feeds the outer-end of the Field-winding
2. on a two speed-motor the Field coil has the same winding as a single-speed motor AND an ?over-wind? of ten turns of resistance wire
3. one end of the resistance wire is connected to the other carbon-brush and comes out of the Motor-case on a BROWN/GREEN wire. I call this the FAST wire.
4. the joint between the resistance-wire and the inner-end of the ordinary copper-wire winding, comes out of the Motor-case using a RED/GREEN wire. I call this the SLOW wire.
5. the self-parker is wired and works just the same as the single-speed motor
6. as is often the case with these motors, the way the switches work isn't very obvious and needs the more detailed explanation below.
FAST RUN
This is easy to understand.
The Slow-switch is open and the Fast-switch works like the switch does on a single-speed motor.
The difference is that the resistance-wire is reducing the current in the Field-winding to about half the value of a single-speed motor and this causes the speed to increase.
Notice that the self-parker will operate in the same way as the fast-switch. So the motor will park at high-speed!
SLOW RUN
This is not so easy to understand.
Suppose we open the Fast-switch and close the Slow-switch. This is the obvious thing to do but its WRONG.
The current in the Field-winding would increase to the value used on the single-speed motors if we did this. But we would be feeding the Armature-winding through the resistance wire.
Two things will now go wrong. The motor won't get the 12A current needed to start.
But worse than this, the resistance-wire will, more or less, receive the whole 12V. This is because the Armature-winding only has a resistance of 1 Ohm and the motor won't run up.
In Fast-run mode the resistance-wire shared the 12V with the Field-winding. It got about 6V. Trust me, at 12V it will get FOUR times as hot as at 6V. You can figure what will happen.
The answer should be obvious by now. The Fast-switch MUST also be closed during the Slow-run mode.
Because both switches are closed there will be NO CURRENT in the resistance wire and the two-speed motor will run exactly like single-speed motor.
So now you know that you must find a three-position switch that does this job AND you have to identify which contacts work this way.
Unfortunately, the usual switch that Triumph used for this job actually has SIX contacts. Some of these are connected to each other all the time. The others jump about, joining to each other in a confusing way, as the switch is pulled.
So you need a test-meter or something to find which contacts work as required.
I checked out one of my spare 3-way Triumph switches, I've no idea if they are all the same as this. The contacts are numbered 1 to 8, except that contacts 3 and 6 were not fitted.
It works like this:
position from contact to contact and contact
IN 7-------------5
MIDDLE 7-------------5-------------4
OUT 7-------------4-------------8
So if you connected:
7 to the car-body (BLACK on a TR4A)
4 to the FAST-wire, (BROWN/GREEN on a TR4A)
8 to the SLOW-wire, (RED/GREEN on a TR4A)
then you would correctly get both speeds.
Contacts 1 and 7 are always joined so you could use 1 instead of 7 this is it suits you.
I have measured some details of the behaviour of these motors, as a means of checking their correct operation. The following data may be useful to others doing the same.
Speed RPM
Supply Voltage
The line in RED is a two-speed motor running FAST
The line in BLUE is a two-speed motor running SLOW
The line in YELLOW is a comparitivle pedestrian early DR2
Note that these motors were ?running-light? without a ?rack? connecting to any actual wipers.
They will run a bit slower when actually in service.
It should be easy to get the DR2 to run like a single speed DR3 with a bit of ?field-weakening?.
FAST RUN
SLOW RUN
It works like this:
IN 7-------------5
Speed RPM
Supply Voltage
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
OK, I found on the web, a copy of the same article, but in .DOC format, complete with diagrams.
Here it is:
I will try extract the diagrams for those who cant read a .doc file.
Here it is as a .PDF file
Here are the two first diagrams. The third picture (speed graph) seems to be incomplete so I haven't done that one.
Here it is:
Craven wrote:Blimey Bill, computers in 1962 what were they valves and relays. I thought my Commodore Pet and a teletype in 1977 was pioneering stuff.
Ron.
Yes, "Mercury" the first computer I used was as big as 3 living rooms, had valves and mercury delay lines as main components and was the one and only computer owned by the whole of the University of London at the time.
Programs punched up laboriously on punched tape using Teletypes, output was a punched tape which we had to carry back to a teletype to print out to see what it said.
Mercury was similar to but bigger than this Pegasus, which they got working at the Science Museum for several years, but which alas they no longer power on.
https://en.wikipedia.org/wiki/Ferranti_Mercury
