Vacuum Light Switch on Dash
Presumably your problem is that you can't remove the knob from the shaft.
If you look at the pictures at the end of this link you will see a spring loaded pin at the end of the shaft, just push it in with a small screwdriver and the knob will come off.
lotus-twincam-f39/vacuum-switch-t13457.html
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
After taking the knob off, the nut holding it on is deep in the recess. Sometines you can undo it with long pointy nose pliers.
I made a tool from a piece of thin pipe, I cut the end so that there were two points on opposite side of the tube, that fit into the slots in the nut.
I bought one of these...http://www.ebay.com/itm/MG-ignition-switch-nut-tool-lucas-triumph-Jaguar-Austin-Healey-Rover-jensen-Lola-/201173629005?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2ed6e1f84d&vxp=mtr
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
That looks too short to do the vacuum 'switch'; it has a long shaft to the knob.
I've been having exactly the same problem and i've just bought these http://www.ebay.co.uk/itm/371229856843? ... EBIDX%3AIT
Grizzly - Coveted Fifth Gear
No, there is a large hole right through it, you use a spanner/wrench on the tool.
Phil Harrison
I knew the old box spanners would come in handy,one end flick switches,the other ignition switch...
10 minutes with a file....
