what's this wire for?
Red/Black wire in the engine bay, comes out of the same part of the loom that feeds the washer pump.
The wiring diagram shows it feeds something but can't decipher what it's supposed to be, also there isn't anything it could connect to.
Any ideas?
David
Any ideas?
David
- djb222
It's for the SOVY device that you don't have on a non-Federal RHD car
You can just see it in this picture of my engine bay:
It's not adding lightness, but it meant that looms could be shared between federal & non-federal cars.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
pharriso wrote:It's for the SOVY device that you don't have on a non-Federal RHD car
On my Fed Sprint thist part doesn't exist, what ist the SOVY device for?
- 1972 Lotus Elan Sprint LHD/DHC
- 1962 Austin Healey Sprite MK II - Sold 09.05.2016
Sorry for my bad survival English
mariodschy - Second Gear
mariodschy wrote:pharriso wrote:It's for the SOVY device that you don't have on a non-Federal RHD car
Mariodschy,
I think that Phil is referring to the brake fluid level sensor cap that is fitted to the reservoir next to the washer bag/pump.It should be connected to a brake warning lamp on the dashboard I have arrowed it below.
Kindest regards
Alan Thomas
Alan Thomas
The wireing diagram says that it goes to the "Servo brake fail switch" but brake fluid level sensor cap sounds better to me.
The question ist what is a "SOVY device"
- Attachments
- Wiring Diagram.pdf
- (78.3 KiB) Downloaded 1145 times
SOVY is I believe the makers name or the trade name for the item.
A good explanation on the Type forums here http://forum.etypeuk.com/viewtopic.php?t=2006&start=100&sid=7af9e13347ef3f709bc37ce9fee0abaf
See this one for sale for a Jaguar http://www.ebay.co.uk/itm/0210-Jaguar-XKE-MK10-420G-420-Sovy-Brake-Bottle-Switches-/221508064768
Kindest regards
Alan Thomas
Alan Thomas
Hello,
a question about how to wire the sovie device in a Federal Sprint. From the diagram there is a switch near the warning light: is it true?
Or does the wiring connect sovie device directly to the warning light? i don't have brake servo.
Could be fine a Black wire ground to the washer pump ground; red wire to the warning light and from here to the positive point on tacheometer?
Finally i found an old sovie device complete, used in bad condition, but nice enough to be restored at http://www.TaylorMadeClassicCars.com
I bought a new one to be adjusted from SNG Barrett UK following the info found here in so
https://www.sngbarratt.com/uk/#!/Englis ... 320daef4e4
thank you.
thank you.
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
umbyfer wrote:Hello,
thank you.
The switch near the warning light is purely to be able to test the warning bulb, it is in parallel to the wiring to the SOVY
You should be able to combine parts to make a nice assembly as long as the can is sound.
I just bought a New Old Stock from a Europa:
Europas used a machine Aluminium container rather than the steel cans that rot through.
Pay attention to the seals to the master cylinder, I found an "O" ring was a better seal than the original flat seal.
Phil Harrison
I think the Sovy uses the same warning light on the Dash as the Handbrake. For sure on UK +2 as on the Elan UK there's no room for a Sovy under the Airbox.
You soon know if there's a problem with the Brake Fluid level the pedal goes to the floor or a Brake Pad has fallen out a Rear Caliper
- alan.barker
alan.barker wrote:I think the Sovy uses the same warning light on the Dash as the Handbrake.
It does on my +2
alan.barker wrote:For sure on UK +2 as on the Elan UK there's no room for a Sovy under the Airbox.
Sorry Alan, but there's plenty of room on a UK +2, mine certainly has it, & most others I believe. The master cylinders are not hidden under the air box as per the Elan, they are up on top, more beside it.
Regards, Tim
- Orsom Weels
Sorry,
but i thought i said Elan no room for Sovy.
I know on a +2 there's room for a Sovy with a Pedal Box.
On my Sprint it's difficult enough just to remove a simple cap.
I can understand why some owners have fitted remote Brake Cylinders.
- alan.barker
Just to add a little information on the Sovy:
1. The test switch is under the dash and is a momentary push button. At least on an original Federal 69 S4.
2. My original Sovy device disintegrated. It always leaked fluid from day 1 (from the factory), either from the container to the tandem reservoir or from the top. I could never get it sealed properly. Went with a simple cap and no Sovy/container as the solution for many years.
3. Replaced the Sovy now with a billet can and cap adapted from a Wilwood remote reservoir. Excellent quality but not cheap. Not original but a tasteful and bulletproof mod IMHO. No more leaks and very solid. Also, replaced my yellowed tandem reservoir with a NOS one, that recently became available.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
