What gauge wire?
These guys have a very comprehensive selection.
http://www.autoelectricsupplies.co.uk/category/10
c42 - Third Gear
I've always had good service from Vehicle Wiring Products - http://www.vehicle-wiring-products.eu
More clues needed The wire gauge depends on what you're wiring. Gauge is slightly different if it's the main power feed (140/180Amp welding wire) or a sidelight (1/2 Amp).
Peter
Peter
PeterK - Third Gear
I was one of the biggest-wire-you-can-find crowd until I read this. I can't remember where it came from.
I've definitely learned to *never* use black unless you know it's directly connected to ground. As we all know, there's always some black wire hanging around looking hopeful when we're trying to find something for a quick fix.
Nick
Nick
elanner - Fourth Gear
Next question
These wires go to the alternator you can see that the large spade connector is very bad. First question, do I need a special connector for the alternator and second question, will soldering a new spade connector on be better than crimping one on?
Gareth
Gareth
To get something you've never had, you need to do something you've never done!
- GHill
Hi Gareth
Generally with a new connector and a wire in good condition crimping is a better option. BUT this only applies to a well made crimp. Use a tool that takes the correct crimp and has a ratchet mechanism that controls the closing force - - that means the connection cannot be "under-crimped".
Soldering is OK but make sure the copper wire and the connector are clean. OK if using new wire and a new connector. Avoid aggressive fluxes that tend to be used with plumbing and sheet metal work. excess heat and too much solder can stiffen up the wire and make it difficult to bend close to the terminal and more prone to break.
Depending on how much work U R doing a multi- purpose ratchet style crimp tool is well worth the investment. For really big leads battery main feed, engine earth and starter motor then I take the tag and the wire to the local electrician and generally they will crimp them 4 U using a high power hydraulic or pneumatic tool - it is so simple 4 them that they very rarely charge more than a price of a pint.
hope this helps
best of luck
Bob
hope this helps
best of luck
Bob
- bob_rich
