S2 Horn replacement
Hi Russ, I fitted a pair of Lucas Windtone horns to my S2 around 2 years ago. I don't know if they are still available. They look very similar to the originals.
I got them from a UK company called Holden Vintage and Classic
Try googling www.holden.co.uk
Ken
Ken
Slightly confused by everything since the invention of the wheel.
- ken ob
Russ, are we still allowed to vote for air horns? I thought that is what the cars came with, or maybe varied by model? Anyway, I got a FIAMM set similar to this one locally...
http://www.ebay.com/itm/Fiamm-Airhorn-K ... 1087706926
Stu
Stu
Stu
1969 Plus 2 Federal LHD
I am planing to replace my standard setup with a compact air horn, as I wont have to find a mounting place for the compressor after my radiator change.
Rdent does a unit for $59.99. There also the "Bad boy unit" at Harbor freight at $39.99, not keen on the name but looks a good option:
http://www.harborfreight.com/bad-boy-ai ... xDwS4Uz134
- mbell
stugilmour wrote:Russ, are we still allowed to vote for air horns? I thought that is what the cars came with, or maybe varied by model? Anyway, I got a FIAMM set similar to this one locally...
Stu
Air Horns are fine. I think air horns weren't available until the S3/S4/Sprint time frame though. Here are the Hellas I was thinking of but I'm open to anything. The Lucas horns I found here in the states as well as reproductions.
http://www.summitracing.com/parts/hla-007424801/overview/
- Tahoe
I have had air horns on my S2 for 48 years since that 18-wheeler tried to run me off the road while I was full on the original "hooter." He never knew I was there. Air horns are great for alerting a vehicle that doesn't see you down there. The only drawback is the delay from the time you jump on the horn button to the time the horns actually make noise. This is caused by the compressor coming up to speed and pressurizing the lines to the horns. This delay also limits the ability to produce a soft "beep, beep" that one often uses to alert another driver that the light has changed or he does not have his headlights on, etc.
I would actually like to replace the air horns with something more instantaneous if they were loud enough. LOUD being the operative word.
Herb
26/4618
Herb
26/4618
Herb
26/4618
26/4618
lotusS2guy - Second Gear
lotusS2guy wrote:I have had air horns on my S2 for 48 years since that 18-wheeler tried to run me off the road while I was full on the original "hooter." He never knew I was there. Air horns are great for alerting a vehicle that doesn't see you down there. The only drawback is the delay from the time you jump on the horn button to the time the horns actually make noise. This is caused by the compressor coming up to speed and pressurizing the lines to the horns. This delay also limits the ability to produce a soft "beep, beep" that one often uses to alert another driver that the light has changed or he does not have his headlights on, etc.
Herb
26/4618
Do as I do, fit a little buzzer type horn in parallel to the air horn for town use. It makes an instant beep, which is then drowned out when the air horns start to make a noise.
Ebay UK about ?6 for a pair today and free delivery. Good idea Bill, which you suggested earlier, and I'm in there.
Meg
