Oil gauge back lighting
The fragility of the capllary tube means this instrument is often replaced.
At times they have been difficult to get hold of?
So there is quite a high probability that yours is not the original fitted.
The early cars had some of the gauges that had "windows" in the side with a bracket also on the side that a bulb fitted into, it then shone into the gauge (in a fashion )
My S2 has at least one gauge with this system, I think the later gauges had the bulb fitted into the actual gauge. Maybe you have a gauge from an early car.
And original Elan oil gauges only went to 60 psi. Many owners, me included, fitted high pressure kits to the engines (my Sprite had 60 psi, so why not the Elan too). This kit pegged the gauge on start-up, so the solution was to fit a gauge with a 100psi scale. My Elans have had 100psi gauges since 1974.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
I had to replace the dual gauge during the rebuild of my S4.
For that I had to send off my original, which accommodated its own lamp holder & in return I got one with those plastic windows in it. Unfortunately that part of the rebuild got delayed & I noticed the difference way to late to expect the supplier to comply with sending my own gauge in reconditioned state back to me..............Grrrr that's the way it goes isn't it folks.
Anyway back to the scientific bit; unfortunately the thickness of the Elan's wooden dashboard effectively blanks off those "windows" so that if an external light source is available it would not illuminate the gauge.
Beware of the Illuminati
GrUmPyBoDgEr wrote: unfortunately the thickness of the Elan's wooden dashboard effectively blanks off those "windows" so that if an external light source is available it would not illuminate the gauge.
Cheers John
Early dashboards were recessed at the back for an external bulb. In my case the bulb holder was part of the bracket holding the gauge in and the bulb pressed against the wood until I modified the holder.
In the S4 you would have to chisel or rout out a similar recess and make a bulb holder to take the existing bulb carrier in the loom.
Meg
The cut-ways as noted in the above post, this dash is from a late S3.
Aha, so the plot thickens; from those photos it would appear that all of the instrumentation in an S3 dashboard is illuminated by external, dash mounted lamps.
Or has that dashboard been modified to do that??
My original S4 instruments all have a lamp holder for an internal illumination lamp, that is of coarse for the exception of that rogue replacement water/oil gauge that has non-functioning illumination "windows" as described in the original question.
GrUmPyBoDgEr wrote: has that dashboard been modified to do that??[/u] John
No, it was the original dash. I cant remember if the new dash had the cut outs, I think it did but will see if I have any pictures of the new dash as I fitted it.
